overfilled oil level 5.0L
A friend at work said that he had accidently over filled his engine with an extra quart of oil. He did not drive it very far before he noticed that at idle the engine only had a 6 psi pressure. Before it would have 40 psi at idle . As the rpm's raised the oil pressure would raise to a normal pressure. He removed the extra oil but so far the oil pressure is still down to around 6 psi at idle. There is no lifter ticking or anything else. The engine is out of a mustang and has themustang type oil pan on it. What could of caused the pressure to drop down?
That engine should be able to handle an extra quart for a short time. The most likely problem from a severe overfill is that there is not sufficient air volume to and the pressure can blow out the seals. It is hard to see this happening at only one extra quart (~3/4") of oil.
I'll admit it I am stumped. All I can say is coincidence, but that does not explain anything. (If your friend had driven without any oil for a while, this would be easier to understand.)
OK, I'll take a guess: The oil pressure relief valve plunger could be stuck, but I do not see how an extra quart of oil could have caused it. Is the 6-psi at hot idle or cold idle?
kitsapcountychopper
04-05-2004 08:56 PM
