Question on codes Injectors.
Old Sep 10, 2011 | 12:39 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
There another 3 injectors bad at cold only.
Well I read someone report that #8 injector are AE but on mine it AD.
It ok to put AE on that #8?
Old Sep 10, 2011 | 04:18 PM
BigAlsPSD's Avatar
BigAlsPSD
AE is known as the "long lead" injector allowing a longer pilot shot I believe, to keep the noise down. It will not "harm" anything.
Old Sep 10, 2011 | 04:44 PM
CSIPSD's Avatar
CSIPSD
Whats leading you to bad injectors?
Old Sep 10, 2011 | 04:50 PM
Milwaukee1979F150
If let sit for like 2 days in little cooler weather in Michigan it wouldn't start without block heater. If outside stay 65oF or above it will start and run but miss badly until warm.
I check with my AE scanner it show #2 #7 #8 during contribution test. 2 mins later Then #2 gone it start work when warm. #7 and #8 stay bad until you drive for like 2-3 miles it go away.
Old Sep 10, 2011 | 10:53 PM
CSIPSD's Avatar
CSIPSD
I would be hard pressed to throw a set of injectors at a truck with that little to go on...
Old Sep 10, 2011 | 10:57 PM
snakedoc's Avatar
snakedoc
i would check the glow plugs and relays.
Old Sep 10, 2011 | 10:58 PM
Milwaukee1979F150
I replaced 3 injectors then mileage went up and it was great. Then now 1 start go bad then couple thousands miles later then 2.
Well I wish I could put 8 new injectors but unemployed so it tougher.
I wish I pull 8 injectors out T444E instead 4. What best part that I only paid $30 for 4 good used injectors
My plan is pull 4 injectors on driver side and replace all o-rings because I suspect I torn one on junkyard injector when install. It was start blow blue smoke at random time like higher HPOP it start leak. It use oil now.
Original injector I pull don't had pink o-ring it was black square o-ring.
Then save $$ for like another week before order another injector for passenger from RiffRaff.
Old Sep 10, 2011 | 11:00 PM
Milwaukee1979F150
They are new. No smoke out exhaust when crank. I use motorcraft glow plugs. But I will test them in morning to see if any bad plug again.
Problem is it worn out or bad injectors not let enough fuel go in cylinders which made harder to start until it plug in block heater for 30-50 mins.
ATV PRO #11
Jul 10, 2015 10:57 PM
mblanken881
Dec 23, 2011 11:39 PM
yz400f
Nov 9, 2011 05:25 AM
Paxdad
Jul 1, 2010 02:56 PM
f1501988
Sep 8, 2004 07:34 PM
