i bought a set about a year ago for a 79 f100 at advance and just looked up full gasket set at autozone,napa,advance all seem to have them. its more than likely a order job or ill have to get it from the warehouse
good luck
buy the pan gasket for the newer FI engine, as it's made of rubber and won't leak, whereas the cork four piece gasket certainly will eventually. It' simple to convert your oilpan to the newer gasket-just grind down the raised surfaces on the face of the pan that hold the cork gasket, and the new gasket fits perfect without leaking.
Did this on both of my 300s. I'm a huge fan of it.
