NEED ADVICE ENGINE SURGES
Old Sep 10, 2011 | 09:43 AM
kjackson's Avatar
kjackson
Left Ogallala Neb campground truck running great started down freeway on ramp pulling strong then lost power engine started to surge and blow black smoke out the exaust. Sat for about 5 min. trying to get a phone number for help and the problem cleared and the truck ran great. Pulled thru the Rockies past Denver with no problem. Now we are in Glen Dale Utah and it happened again this time the engine cleared in about a minute. Do I need to find a Ford Garage or is this just some bad fuel I got? 2004 6,0l with 55000 miles had oil and fuel filters changed about 1500 mi ago. Sorry for long post.
Old Sep 10, 2011 | 10:51 AM
bismic's Avatar
bismic
Find a place that will pull codes (if any) for you.
Old Sep 10, 2011 | 11:14 AM
Unrealo4's Avatar
Unrealo4
Glendale is kinda out in BFE! Try to get to cedar city that's you're best bet for a Ford dealership. But it sounds like you're ICP sensor is going out. I would help but i'm 4 hours north of ya near Lehi.
Old Sep 11, 2011 | 02:12 AM
matty169's Avatar
matty169
Pull the EGR valve
It is probably getting stuck on some carbon chunks. Clean it and look in the intake.
Old Sep 11, 2011 | 11:37 AM
kjackson's Avatar
kjackson
Is thr EGRvalve easy to get out? I am in a campground with limited tools.
Old Sep 11, 2011 | 12:28 PM
kjackson's Avatar
kjackson
Being new to this truck I should have checked the Tech Guides first, if I am reading correctly I should be able to just pull off the wiring harness for now and do the cleaning when I get home. Thanks for the replys.
Old Sep 11, 2011 | 09:18 PM
Coronado's Avatar
Coronado
Start checking the ICP and then check your FICM as well to be sure. Then I would start diagnosis on the injectors and fuel system.
Old Sep 11, 2011 | 09:39 PM
BLADE35's Avatar
BLADE35
you can try to see if unplug EGR valve helps BE Very Careful it is in with the Fan Operation and maybe affected
watch coolant temps with more than the dash gauge when you see hot on that it maybe to lait
just go easy on it if you do
are you pulling a trailer from the campground????
Old Sep 12, 2011 | 08:48 AM
kjackson's Avatar
kjackson
Yes we are pulling a 5th wheel. Theproblem is yhis is a very small without a garage and I have limited tools to work with. We are going to try to make it to Moab today,I see they have a Ford dealer there hopefully they will be able to help.
Old Sep 12, 2011 | 08:54 AM
kjackson's Avatar
kjackson
Yes we are pulling a 5th wheel, we are going to try to make to Moab today I see they have a Ford dealer there may I can get service there.
simbrn
Oct 19, 2015 12:16 AM
kojock
Nov 12, 2009 07:06 AM
dyhrdford
25
Jun 3, 2009 10:33 PM
jtharvey
568
Mar 5, 2009 04:15 PM
Bustaduck
Dec 29, 2007 08:07 AM
