Sponsored by: Auxito
milage increase
Old Sep 9, 2011 | 08:06 PM
trober_603's Avatar
trober_603
milage increase
is there any ways to increase milage ive got a 99 ford f150 4.2l v6 5 speed 2wd and im doing good on milage but i wana squeze just a little more out of it.. i know keep your foot out of it but i was jsut looking for add on's like chips or whatever would help milage alot but i dont want to spend 3 or 400 on a programmer.. any suggestions?
Old Sep 9, 2011 | 10:40 PM
Hybris's Avatar
Hybris
Not much you can do without spending cash.
You could start by taking anything out of your truck that you don't need to carry with you all the time (tools and the like), maybe remove your spare tire if equipped. If you are handy with wood or better yet fiberglass or aluminum you can fab up your own fastback style bed cap.
After that you got to start spending money a tuner will likely not do a whole lot to improve mileage but then again it might work. Here are a few other ideas.
  • If you have bench seat or split bench seat take out either whole seat or just the passenger side seat and track you will save a noticeable amount of weight by doing this.
  • Lower your truck a few inches to give it a smaller frontal profile.
  • Maybe invest in a body kit or better yet make one your self.
  • Get the lightest, thinnest, and hardest wearing tires possible the light weight of the tires will mean the engine has less mass to turn and the thin profile of the tire will mean less contact with the ground thus less rolling resistance and the hard non-squishy tire material will not only last longer but lower the rolling resistance even more.
  • Custom cut polycarbonate windows and windshield.
  • The lightest weight 16" wheels you can find.
  • Re-gear your rear end to a higher ratio like 3.31 or higher.
These are extreme measures but I can say that you would get the mileage increase you are looking for just be aware that these changes will change how the truck will handle and the weight limit it will take.
Old Sep 9, 2011 | 10:43 PM
Bluegrass 7's Avatar
Bluegrass 7
No ways to do what you want with low cost add-ons.
Harder tires, fresh front OX sensors if they are old and training your brain/foot to use less throttle, especially after cresting a hill, into not holding so much throttle opening when it's not needed and running about 55 +/-.
Were all guilty of it.
Good luck.
LadderDogV10
Jun 13, 2017 08:13 PM
HoustonDave
Sep 15, 2016 09:09 AM
bridge
2004 - 2008 F150
Jun 8, 2009 01:04 AM
mbogosia
2004 - 2008 F150
Nov 19, 2007 06:25 AM
jessfactor
General Automotive Discussion
May 24, 2004 03:14 PM
