Sponsored by: Real Truck
parking brake
Old Sep 9, 2011 | 01:03 PM
getnbz's Avatar
getnbz
parking brake
hi
i need to know the parking brake circut and where to tie into it. need to hook into it so my dvd player will work it wont play unless the brake is on any help guys thnx
Old Sep 9, 2011 | 01:12 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
What DVD Player do you have? Sometimes there is an easier way to do it.
Old Sep 9, 2011 | 01:26 PM
getnbz's Avatar
getnbz
jensen VM 9314
Old Sep 9, 2011 | 01:29 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Try connecting the parking break wire to a ground wire.
Old Sep 9, 2011 | 02:45 PM
getnbz's Avatar
getnbz
i have the wire to connect to parking brake i just dont know where it is i took kick panel off i dont see any wires
Old Sep 9, 2011 | 03:05 PM
2000silverbullet's Avatar
2000silverbullet
PM sent with link. Not sure it'll work because it doesn't specify your model but had some close to it.
Old Sep 9, 2011 | 06:03 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Take the parking brake wire from the radio and connect it to a ground wire. That should work.
Old Sep 9, 2011 | 06:16 PM
2000silverbullet
From what I remember, on alot of the older units, you can get away with just grounding the parking brake wire that comes off the stereo but on the newer ones, they integrate other measures (i.e. it detects movement from the gps signal and disables the dvd) to avoid this hack.
I'm not familiar enough with that unit to say one way or the other though...
Old Sep 9, 2011 | 06:19 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by 2000silverbullet
On alot of the older units, you can get away with just grounding the parking brake wire that comes off the stereo but on the newer ones, they integrate other measures (i.e. it detects movement from the gps signal and disables the dvd) to avoid this hack.
My unit works off of a +12V but only if the unit has been on for about 10 seconds, then gets the +12V so simply wiring it to a +12V wont work. They way around it is to get a relay, hook one end up to the units "remote power" and then the other end of the relay to the parking brake wire for the unit. The remote power gets +12V about 10 seconds after being turned on, and then will trigger the parking brake wire, and now the unit things youre in Park.
Gage2502
Sep 5, 2012 04:39 PM
85MD
Oct 19, 2010 02:46 PM
ryanb464
Nov 5, 2009 11:39 AM
desertford
Jul 23, 2007 08:15 AM
F-7
Nov 1, 2004 11:20 AM
