axle upgrade
Old Sep 8, 2011 | 02:13 PM
the stranger's Avatar
the stranger
axle upgrade
hey ford guys...question: I have a 79 4x4 automatic with stock front and rear axles; 9" and dana 44, and I put 42" super swampers all around. will the stock axles hold up, or should I consider swapping out for 3/4ton axles?
Old Sep 8, 2011 | 02:51 PM
montana_highboy's Avatar
montana_highboy
Depends on how you intend to use the truck, generally speaking, those axles in stock form are good for up to 37's, but if you're just cruising around town in the truck i.e. mall crawling, then you'll probably be just fine, on the other hand, if you're going off-road and/or beating the truck hard the 42's will reveal the inherent limitations of those axles in very short order, in that case some bigger axles would be the way to go e.g. D60's front and rear.
Old Sep 8, 2011 | 02:55 PM
the stranger
thanx for the response...I kinda thought I'd be needing to upgrade cause Im doing some swamping and spent last saturday pulling other trucks out! better get a winch for that..plus just starting what I think is a major rebuild with the truck
makingaZJ
Apr 5, 2011 07:33 PM
nordvik72
Dec 16, 2009 10:16 AM
mudslingur
Mar 14, 2007 05:42 PM
Rintin69
Offroad & 4x4
Apr 28, 2006 08:55 AM
MEPR
Offroad & 4x4
Feb 19, 2003 01:56 PM
