I want the chrome MotoMetal's in a 17' with a 285 tire. I am being told that the offset of this rim (12mm) will not work and will rub... I am 100% stock. Regards, John
Not sure on stock height if it will rub. May need to pull back the front wheel liner and trim the front air dam which are both fairly simple. Maybe someone else can post if a 285 on 17 will fit.
I have done a few searches...Seems folks are all over the map with sizes.. I just want to run a 285 aggressive tire / with a 17' rim ! Will this work?? And if so...what backspacing?? Someone has to know and have proof.....Thanks Again..John
Reason: adding info
