2008 F250 stepping down to 17" wheels
I'm looking to dress up my rig with new wheels and tires... I"m considering going down to 17" wheels from the stock 18" (the only other stock option was 20").
The reason being: There seems to be more size options in 17, and both wheels and tires and the cost seems to be about about 20% less, at minimum.
Does anyone have a 2008+ with a 17" wheel setup (Pics would be great)?
Also, are there any mechanical reasons I shouldn't do this (will the narrower rim not clear something)?
Thanks,
Scott
Thanks,
Scott
Originally Posted by Superdave71
I know at some point 18" became standard because brakes wouldn't fit in the 17, not sure if it was 08, or 11. Make sure they'll fit
I personally like 17's. The tire looks bigger, and you get more cushion between your wheel and the road, making for a better ride. Cheaper tires is a bonus. Unfortunately, I had to go with 18's to get an e rated tire in a 37x12.50.
Ron is right, 17's do fit and are still the factory wheel on the 2017 SD. I ran 17's on my 2016 and I can say that the clearance was very close. I ran American Racing 17x8.5 "0" offset. Each wheel is a little different and depending on the offset and thickness of the alloy will make you anywhere from real close to just enough clearance for comfort.
The following users liked this post:
Maybe 17" steel, but there was a guy buying a 16 at my dealer who wanted to keep the 17's on his trade, and they wouldn't fit. At some point the brakes got bigger.
Highmark18
1999 to 2016 Super Duty
09-19-2013 12:26 PM
