axle pivot drop brackets
Old 09-07-2011, 09:39 PM
xc4jokestomper's Avatar
xc4jokestomper
xc4jokestomper is offline
anyone know where i can find some info on the drop brackets to fix the alignment? i put a leveling kit on my truck and im having problem with the camber. so im guessing i need drop brackets for about a 2" lift. drivewire or whatever used to sell them but i dont see them listed anymore. bronco graveyard has them for a 4-6" lift and the stock set up but none of a 2".
or better yet does someone have a template of them? ive got a buddy of mine offering to make me a set if i can find out what they look like, what size, and all that good stuff.
picture or links or anything would be helpful
Old 09-07-2011, 11:09 PM
Beatertruck's Avatar
Beatertruck
Beatertruck is offline
1987-1993 Ford F-150 Camber and Alignment Kit - Moog K8746 - Front
You can use the stock ones. They will give you plenty of camber adjustment for the leveling springs.
Old 09-08-2011, 10:28 AM
xc4jokestomper
Is that the kit that will drop my axles down a little bit? My alignment guy sai i need drop brackets but i dont really trust him.
Old 09-08-2011, 10:46 AM
andym's Avatar
andym
andym is offline
For a two inch kit you don't need drop brackets. What you need are camber bushings designed for a 2" lift on your truck. A good offroad shop will know what you're talking about.
Old 09-08-2011, 01:33 PM
nvrsatisfied84's Avatar
nvrsatisfied84
nvrsatisfied84 is offline
tuff country makes them u can use the eccentrics but the usually start binding upper ball joint the cams work way better
Old 09-08-2011, 01:43 PM
xc4jokestomper
I ordered the camber bushings designed for the kit. I purchasedthe kit that came with the springs and bushings from bronco graveyard.
Old 09-08-2011, 01:47 PM
andym's Avatar
andym
andym is offline
So you've already installed the camber bushing kit designed for the 2" lift?
How far out is your alignment?
Old 09-08-2011, 02:16 PM
xc4jokestomper
Yeah they came with the springs.
They said its about 4 degrees. My wheels are sitting like \ /
Old 09-11-2011, 08:02 PM
ItsAFord55's Avatar
ItsAFord55
ItsAFord55 is offline
i just did the same thing on my 1991 and shops have been telling me that its gonna costs hundreds to fix it....even offroad shops..............but my friend said that theres a hex nut on top of my upper ball joint that will adjust the camber ....im gonna give it a try tomorrow
Old 01-27-2012, 02:53 PM
Southern Buckers's Avatar
Southern Buckers
Southern Buckers is offline
Does anyone have or know where I can get a set of the stock pivot brackets for a 1997 F250 4x4 with the TTB front end? Can I order these from the bronco graveyard?
Old 01-27-2012, 03:22 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
You're best bet for those is gonna be a junkyard I bet. Also check out the classifieds, someone may be parting out a 250.
Old 01-27-2012, 04:44 PM
thechief66's Avatar
thechief66
thechief66 is offline
Those are still available from Ford. $54 for the left and $43 for the right.
6.9idiatsturbo
06-02-2014 08:20 PM
460_Maniac
04-25-2007 01:38 PM
dale gribble
10-19-2005 06:00 AM
Mush's 88
08-04-2004 03:01 PM
MRStace84
12-27-2003 12:00 AM
Quick Reply: axle pivot drop brackets
