Pump name?
Old Sep 7, 2011 | 08:53 PM
Vinford's Avatar
Vinford
Pump name?
I think I need a new vacum/air pump ?
2002 F-350 7.3
Air conditioner wont always work , same with heater and 4x4.
They are all run by the pump under the hood arent they?
I was looking on Ebay for one but am maybe not using proper name?
Old Sep 7, 2011 | 09:06 PM
bulla's Avatar
bulla
Could just be some leaks! Do you notice when it acts up, like when it's in 4 wheel drive or is it more a random kinda thing?
Old Sep 7, 2011 | 09:13 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
I think this is what you are looking for, But I'm with Bulla would look for leaks before replacing the pump.
OEM NEW Powerstroke Diesel Vacuum Pump 7.3L 6.0L 99-10 | eBay
Old Sep 7, 2011 | 09:38 PM
Vinford's Avatar
Vinford
The 4x4 hasnt worked proper for a long time but the ac and the heater always worked.
I figured a leak probably going to the front wheels but that wouldnt affect the ac would it?
Old Sep 7, 2011 | 09:50 PM
bulla's Avatar
bulla
It would if you were trying to use the 4x4. If I'm not mistaking, when you have a vacuum leak at the front hubs and you try to use 4x4 high or low with the esof it will default the ac to blowing out the defrost due to a loss in vacuum. If it does it just randomly not in 4x4 then this would not apply.
Old Sep 7, 2011 | 10:00 PM
Vinford's Avatar
Vinford
AC works randomly and seems to have something to do with starting the truck.
Sometimes , shutting off the truck then restarting will let the AC work.
Fan and stuff blows but nothing comes out the AC vents.
Sometimes hot air blows out the AC vents.
AC works well when its coming out the right holes.............
mscheel
Jun 1, 2015 09:31 PM
andrewc53
Dec 22, 2011 05:22 AM
Sedan300
Jun 3, 2009 02:13 PM
trakman
Dec 5, 2005 09:20 PM
Quadzilla
Dec 18, 2002 12:54 PM
