08+ tail light conversion
Old Nov 12, 2011 | 10:11 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by SpringerPop
Trey,
"Makeshift" and "contraption" kinda' implies that Robin would do something sub-standard to his truck. Most of us can assure you that nothing could be farther from reality.
Over the years, Robin has established himself as doing top-quality work, and if he deemed it OK to use aftermarket parts in this application, I'd not think twice about doing the same.
Pop
Noo.. Not implying Robin did anything like that. I just havnt had good luck with AutoZone off brand electronic components.
Old Nov 12, 2011 | 10:35 AM
SpringerPop's Avatar
SpringerPop
Yup! That's a far-better way of expressing it, with no implications.
Pop
Old Nov 12, 2011 | 01:26 PM
Supercab's Avatar
Supercab
Guys, I sold Frank the '08 tail lights after looking at them closely and finding out that they DO take a smaller bulb (like the little ones that are commonly used for side marker lights on some cars) I don'y feel that there is a bulb that small that can be had to put out the light the originals do either in LED or the extra brights that some claim.
IF I had gone ahead and installed the '08 lights I would have bought the sockets for the bulbs at Autozoo or somewhere else and used a scotch-lok type deal to attach them and left the original sockets dangling behind the lights so they could be switched back someday.
I just don't see why Ford went this route-was it to save .05 on the overall cost to build the '08 up trucks?
Old Nov 12, 2011 | 01:58 PM
PaysonPSD's Avatar
PaysonPSD
The 921 bulbs I used in my 2008 tail light conversion are the same as what was used in the 2008. I checked the 2008 owner's manual. It's not the size of the bulb but the wattage, reflector behind the bulb and the lense the light shines through that determines the brightness. The 921 backup lamps are every bit as bright, if not brighter, than stock backup lamps.
If you need more backup lighting then add some auxillary backup lights.
Almost a year and a half later and no problems with the backup lights.
Pop,
Thanks for the vote of confidence.
Old Nov 12, 2011 | 02:17 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by microdevil45
I was looking to do this what small part would I need?
This is the driver side hinge part you need to install the '08+ tailgate. I paid less than 7 bucks.
Old Nov 12, 2011 | 02:32 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
There is MUCH more to do with light output than bulb size. Wattage, construction, filament material, reflectors, housing...
For example look at the bulb housing. The 99-07 one is hazy and has no diamond like reflectors, just a chrome painted back (IIRC). The 08+ has a clear lense and directed diamond like reflectors.
Case in point, look at street lights. Remember how they used to be a yellow orange? Most places have converted to newer bulbs or LED variants that have more light output in the same lamps
Old Nov 12, 2011 | 08:16 PM
microdevil45's Avatar
microdevil45
That is awesome.... Thanks
CJ-8_Jim
2015 - 2020 F150
May 28, 2015 06:32 AM
Lizzy2003
2009 - 2014 F150
13
Mar 17, 2014 06:53 PM
cbzdel
Mar 25, 2012 08:18 PM
Supercab
Ford Truck Parts for Sale
Oct 1, 2011 03:06 AM
