You seem to come up with info that can't be found anywhere else. Can you come up with info on the motor mount perches for dentside 2wd 429/460? Also availability please.
1973/79 F100/350 460 (no 4WD 460's until 1983, ditto a M/T).
D3TZ-6028-A Right & D3TZ-6029-A Left .. Engine Supports
D3TZ-6030-A Right & D3TZ-6031-A Left .. Engine Brackets.
2) D3TZ-6038-A .. R/L Rubber Insulators.
The brackets bolt to the block, the insulators bolt to the brackets, then to the supports.
D3TZ-6A023-A .. Rear Engine Mount Bracket (some peeps call it a trans crossmember).
D3TZ-6068-A .. Rear Rubber Insulator (some peeps call it a trans mount).
All these parts are obsolete. Last time I looked, no one had the supports and brackets. Only a coupla sources had the insulators, but they can be bought in parts stores.
429's were not installed in F100/350's, but use these same parts since the block is essentially the same.
