460 engine block brackets
Old Jul 28, 2008 | 08:59 PM
dani9678's Avatar
dani9678
I got a 460 that came out of an RV with a van front clip and so basically it came out of an E-250 and it is going in my 77 F100. What I want to know is are the brackets that go between the rubber part of the mount assembly and engine block the same for F series trucks and E series vans? I guess you could call them the hat part of the assembly. They bolt to the block. That would be great if they are the same. That would be one less thing that I need to change.
Old Jul 28, 2008 | 09:46 PM
tenforty_2's Avatar
tenforty_2
This is a tough question to get answers for! I have been reading threads for weeks looking for answers regarding my swap and still don't have what Iam looking for.
Old Jul 29, 2008 | 08:54 AM
dani9678's Avatar
dani9678
"The support brackets (D3TZ-6030-A R/S & D3TZ-6031-A L/S) bolt to the engine"
The support brackets that came on the engine look the same when you place them beside each other.
Old Jul 29, 2008 | 09:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350 460 engine mount brackets and rubber mounts are NOT the same as 1975/79 (or any year) Econoline 460's use.
Econoline mounts will not work on F100/350's regardless of the year, or engine size.
D3TZ-6028-A .. R/S Engine Mount Support Bracket (to crossmember) / D3TZ-6029-A .. L/S Engine Mount Support Bracket (to crossmember).
D3TZ-6030-A .. R/S Bracket (to block) / D3TZ-6031-A .. L/S Bracket (to block).
2) D3TZ-6038-A .. R/L Motor (rubber) Mount
The rubber mounts bolt to the engine mount support brackets (6028/6029), and nestle inside the brackets (6030/6031) that bolt to the block.
Econolines do not use the 6030/6031 brackets, the Econoline support brackets (D7UZ-6028-A & D7UZ-6029-A) are not the same as the ones used on F Series trucks.
The transmission rubber mount and bracket (aka crossmember) is F Series truck only.
Old Jul 29, 2008 | 09:52 AM
dani9678's Avatar
dani9678
Well in that case, does anybody have pics of the engine block brackets so that I can see what they look like in order to avoid getting the wrong ones if I buy them off ebay?
Old Jul 29, 2008 | 10:03 AM
NumberDummy
Originally Posted by dani9678
Well in that case, does anybody have pics of the engine block brackets so that I can see what they look at in order to avoid getting the wrong ones if I buy them off ebay?
There are several ppl here that have the 1973/79 Ford Light Truck Parts Catalog on a CD that can scan and post the illustrations, but neither is online very much.
As I see it, you have two choices.
1) Go to your local dealer...the illustration in the above Ford parts catalog (Section 60.1 / Page 6) of what all the F100/350 460 front/rear mounts look like, is very clear.
2) Buy your own copy of this exact same CD catalog, it's available from hipoparts.com / also sold on ebay / the price is around $25.00.
Since the catalog has illustrations of every single part, not only do you get all the part numbers, but the catalog can be used as an assembly/dis-assembly manual.
The Big Dummy would like to help you.....but I'm using the above parts catalog on Ford microfiche slides.
EDIT: I believe Summit sells the 460 mounts & brackets.
Old Jul 29, 2008 | 10:40 AM
dani9678's Avatar
dani9678
I went to the Summit site but all I could find are aftermarket swap mounts and brackets. The Dealer doesn't go back any further then 84 I believe which wouldn't work. I was looking on ebay but some people don't know what to call the part so I have to try different names but so far no go. Right now I have the frame mounts (perches) so what I have left to get is the plates.
Old Jul 29, 2008 | 10:59 AM
NumberDummy
Suggestion:
Call obsolete Ford parts dealer Green Sales in Cincinnati, Ohio and ask them to fax you a copy of that engine mount illustration from the parts catalog.
EDIT: I just typed the part numbers into their website > >
> > They have ALL the parts NOS (new old stock). The support brackets, the engine to block brackets, the rubber engine & trans mounts...the whole tamale.
Here's the info again: 1973/79 Ford Light Truck Parts Catalog / Illustration Section 60.1 / Page 6.
greensalescompany.com / Help line: 513-731-3304 / Part number check = 800-543-4959.
Old Jul 29, 2008 | 11:15 AM
dani9678's Avatar
dani9678
I just got off the phone with Greensales and they said that the cost of the plates will be $200 a piece. Well, At least I know that have them.
Old Jul 29, 2008 | 11:18 AM
Rebel Warrior's Avatar
Rebel Warrior
Smile 460 mounts
I have a set of 1977 F250 2wd mounts complete. I can take pics if you'd like let me know.-RW
Old Jul 29, 2008 | 11:23 AM
NumberDummy
That's a bit...uh...hell, that's waaay too much! Sounds like a price Ben Dover Motors would charge!
The member above has the parts...they're the same for all F100/350's 1973/79.
Old Jul 29, 2008 | 11:59 AM
dani9678's Avatar
dani9678
Yeah, I wonder if he would be ok with me just buying the top pieces, the block to motor mount brackets. If the rubber motor mounts are good I'd buy them also. I wouldn't need the frame mounts because I already got those from another member here by the name of "76CREW" or is it"76 CREW". He went thru the trouble of mailing them over to me to try before I buy them. He even sandblasted them and put on 4 coats of paint.
Rebel Warrior, how much would you take for the engine-block-to-motor-mount brackets?
Old Jul 29, 2008 | 12:02 PM
Rebel Warrior
$5.00 each. plus shipping. from 95338 to your place. whats your zip?
Old Jul 29, 2008 | 12:10 PM
dani9678's Avatar
dani9678
My work zip is 34668 and my house is 33541. Let me know which is cheaper for you. I like to have it shipped to my work because I am there 5 days a week and if there is no one at the house I run into problems.
Old Jul 29, 2008 | 12:28 PM
Rebel Warrior
Smile
These quotes are if the package will be sent by aug 1st
<TABLE class=dataTable cellSpacing=0 cellPadding=0 border=0><TBODY><TR class=""><TD vAlign=top>UPS 3 Day Select® <!-- TODO - get bundle key for express description --></TD><!-- end column 1 cell - service and days in transit --><!-- start column 2 cell - Guaranteed By commit time --><!-- No column 2 cell here for express critical colspan --><TD vAlign=top>By End of Day,
Wednesday
August 6, 2008 </TD><!-- end column 2 cell - Guaranteed By commit time --><!-- start 2-colspan column 3&4 cell - Total, Billable weight and start express critical colspan=2 --><!-- if express critical, show link in column 3 and nothing else --><!-- end 2-colspan column 3&4 for express critical --><!-- if not express critical, display 3rd column billing, and 4th column ship button --><TD vAlign=top noWrap>43.79 USD<SUP>*</SUP>
<INPUT type=image height=14 alt="View Details" width=74 src="https://wwwapps.ups.com/img/en/btn_lnk_view_details.gif" border=0 name=7>
<!-- original code from vhtml - uses <img> instead of <input> - I kept <input> but may want image dimensions from vhtml code below View Details</td> --></TD><!-- end column 3 cell - Total and Billable weight --><!-- start column 4 cell for ship button column --><!--RFC 3180 Aug 06 Maintainence release added by sunil mitta --><TD vAlign=top><!-- vhtml code is as follows: <input name="repl_name2" type="submit" value="Ship" class="btn_a" > vaughn --></TD><!-- end column 4 cell for ship button --></TR><!-- end 1st iterated row --><!-- start 2nd iterated row - days in transit --><TR class=""><TD class=indent vAlign=top noWrap>Days In Transit: 3</TD><TD vAlign=top> </TD><TD vAlign=top noWrap>Billable Weight:
10.0 lbs. </TD><TD vAlign=top> </TD></TR><TR class=odd><!-- start column 1 cell - service and days in transit - colspan=2 if ups express critical --><TD vAlign=top>UPS Ground <!-- TODO - get bundle key for express description --></TD><!-- end column 1 cell - service and days in transit --><!-- start column 2 cell - Guaranteed By commit time --><!-- No column 2 cell here for express critical colspan --><TD vAlign=top>By End of Day,
Friday
August 8, 2008 </TD><!-- end column 2 cell - Guaranteed By commit time --><!-- start 2-colspan column 3&4 cell - Total, Billable weight and start express critical colspan=2 --><!-- if express critical, show link in column 3 and nothing else --><!-- end 2-colspan column 3&4 for express critical --><!-- if not express critical, display 3rd column billing, and 4th column ship button --><TD vAlign=top noWrap>15.35 USD<SUP>*</SUP>
<INPUT type=image height=14 alt="View Details" width=74 src="https://wwwapps.ups.com/img/en/btn_lnk_view_details.gif" border=0 name=8>
<!-- original code from vhtml - uses <img> instead of <input> - I kept <input> but may want image dimensions from vhtml code below View Details</td> --></TD><!-- end column 3 cell - Total and Billable weight --><!-- start column 4 cell for ship button column --><!--RFC 3180 Aug 06 Maintainence release added by sunil mitta --><TD vAlign=top><!-- vhtml code is as follows: <input name="repl_name2" type="submit" value="Ship" class="btn_a" > vaughn --></TD><!-- end column 4 cell for ship button --></TR><!-- end 1st iterated row --><!-- start 2nd iterated row - days in transit --><TR class=odd><TD class=indent vAlign=top noWrap>Days In Transit: 5
the package will weigh about 10lbs.
by the time they are packed up.
did you just want the engine side,
the pieces that bolt to the block
only??? or do you need the frame
brackets also? this quote is for the
engine side only.if you need frame
brackets also shipping will be more
10.0 lbs.
</TD></TR></TBODY></TABLE>
