300 I6 Sparkplugs
Old Sep 6, 2011 | 07:17 AM
PAJ29's Avatar
PAJ29
300 I6 Sparkplugs
I just bought a 92 F150 with a 300 I6, it has been missing so im changing the spark plugs and the wires while im at it, the old sparkplugs are so rusted i cant unscrew them, ive already tried WD40 and PB Blaster, sitting over night, ive even broken a ratchet on one, given it was a cheap tool, but still. any suggestions?
Old Sep 6, 2011 | 12:51 PM
LCPullman's Avatar
LCPullman
Well all I can say is use more penetrating oil, Break Free has worked pretty well for me in the past, its a little heavier than WD-40 and can penetrate better given time.
May be every evening put on more oil (more often wouldn't hurt), until the plugs will break loose.
May be when you put the new ones on you could used just a touch of anti-seize lubricant.
Old Sep 6, 2011 | 01:16 PM
msgtord's Avatar
msgtord
I have put the oil on the plug then drive it for a few days, putting oil on the plug after each run. Then give it a try.
Old Sep 6, 2011 | 06:34 PM
Greg B's Avatar
Greg B
Did you try breaking them loose with a breaker bar instead of a ratchet? It usually works for me.
Old Sep 6, 2011 | 06:40 PM
LxMan1's Avatar
LxMan1
Moved to correct forum.
Old Sep 14, 2011 | 08:05 PM
big-ugly's Avatar
big-ugly
As mentioned before, soak the crap outta the plugs with a penetrating oil (I only use PB blaster) and repeat the process until they finally break free. (Cheater-bar on a breaker-bar may be your best friend). Been there done that.. Be extremely careful not to break a plug, and use your head. If you get it to break free, even slightly, use the back and forth method. Loosen it a little, tighten it a little, loosen it a little, tighten it a little... etc, etc, etc.. You will eventually get them.
Old Sep 28, 2011 | 12:33 AM
publiuss's Avatar
publiuss
Ditch the WD-40, it's not a penetrating oil. The best penetrating lubricant is Kroil. PB Blaster is good too. Just keep spraying it on every hour or so for several hours then use the breaker bar like others have recommended.
Old Sep 28, 2011 | 07:29 PM
jahollis2380's Avatar
jahollis2380
Omg!!! That engine ran so long the spark plugs rusted in it???? Ive worked on some crappy stuff before, either it was abused to know end or it was just ran that long either way kudos to the i-6!!!!! I know i falling head over heels with my newly aquired 89 bronco with the i-6!!!!
Old Sep 28, 2011 | 07:39 PM
jahollis2380
Old Sep 28, 2011 | 09:25 PM
big-ugly's Avatar
big-ugly
It's not uncommon for any engine to have sparkplugs rust in after a long period of time... especially if no anti-seize is used...
ColeT24
Feb 16, 2015 09:11 AM
PAJ29
Sep 9, 2011 10:59 PM
FarmForward
Dec 19, 2006 10:05 AM
TallPaul
Nov 25, 2002 09:02 AM
hl649
Oct 24, 2002 10:39 AM
