Painting Steering Wheel
Old Sep 5, 2011 | 09:48 PM
pgr380's Avatar
pgr380
Anyone have advice on painting a steering wheel? Wheel has been sanded and prep'd. Will a good quality gloss enamel in a spray can do the trick?
Old Sep 5, 2011 | 10:06 PM
thorswhisper's Avatar
thorswhisper
Theres Prep, then theres Prep
Gloss enamel in a spray can probably wont hold up long. Prep has a lot to do with durability. Id recommend a good catalyzed epoxy primer X2 coats, followed by a catalyzed acrylic enamel at minimum. A urethane would probably be better.
Old Sep 5, 2011 | 10:59 PM
Ki-Adi-Mundi's Avatar
Ki-Adi-Mundi
I recently used spray can primer then used a enamel spray paint. I took time to prep it well and fill in all of the age cracks. It turned out looking amazing (much better than I thought it would). I would say its a great way to paint it but I just don't know how long it will hold up.
Old Sep 5, 2011 | 11:13 PM
Bill W's Avatar
Bill W
if you finish it with a good quality clear it should hold up for a while.
Old Sep 6, 2011 | 08:43 AM
CropDusterMan's Avatar
CropDusterMan
Do yourself a favor...if you go the DIY route...use high quality primers, paints and clear-coats. I restored
my wheel a year ago and it's still pristine.(used daily in Hot CA sun) I use PPG for all the above...only thing
really, is it costs a bunch to get the materials...literally, several hundred dollars...the price of a new wheel!
(But the new wheels are only Black)
As I use all these paints regularly, it wasn't a big deal for me...but you might be best taking your wheel to an
auto-body shop and have them do it?? Might cost you $50-80?
One thing I've learned, nothing on these trucks is cheap to do...you could rattle-can it with your primer and
color of choice and a few coats of clear...but I doubt it'll last.
Hope this helps a bit....
JBone
Old Sep 6, 2011 | 11:47 PM
tbm3fan's Avatar
tbm3fan
Spray can sounds nice and easy but how long will it stand up to your hands over time? Luckily I happened across a beautiful turquoise wheel that is pristine. Given that all I need to do is scuff the surface before shooting with Holly Green paint. The paint will be PPG Concept single stage urethane. Now if I had a new black wheel I would first clean well and coat with a flex sealer to promote adhesion before moving onto a primer and color coat.
ajbremer
Feb 4, 2015 08:50 AM
Shadowrider123
13
Jan 16, 2015 02:12 PM
JefflovesF250s
Jan 4, 2009 08:43 PM
Kenny
Jan 7, 2002 05:34 PM
cashmoline
Jul 26, 2001 04:48 PM
