Hi pinion headers
Old Sep 5, 2011 | 09:47 PM
turbohunter's Avatar
turbohunter
Hi pinion headers
Working on my truck the other day I took a look at the coming up problem of header fit.
I have a high pinion 44 and from what I can see the header fit will be crucial.
The engine is a 360.
F-100 4x4 shortbed.
Anybody have experience with this set up?
Old Sep 5, 2011 | 11:07 PM
Jetcopterpilot's Avatar
Jetcopterpilot
Sanderson Headers for Ford FE 332-428" engine applications. These guys will make things to fit! That is how I did mine I have their model FF427 modified but mine is 2wd! Give them a call they will have you take a few measurements, and then they just make them up to fit. I had mine in less than a week, and they just bolted right in! They are a block hugger shorty, but it is just a mater of Routing the pipe after the collector, around your Axle...
Old Sep 5, 2011 | 11:31 PM
turbohunter
Yeah, figured it may be a block hugger setup.
That drive shaft is dead on below.
Just curious if anybody worked it out with longer tubes.
Old Sep 6, 2011 | 09:00 AM
daningraham's Avatar
daningraham
I took mine down to the muffler shop and they rerouted the collector to accomodate the high-pinion set up when I swapped the low pinnion 44 for the high pinion 60.
Amphihauler
Jan 29, 2017 08:16 PM
hawaiian-style
Apr 9, 2008 11:15 AM
1976 ranger
Offroad & 4x4
Oct 31, 2003 01:02 PM
popman
Exhaust Systems
Mar 14, 2003 06:14 PM
