Highboys with High pinion Axle ???
Have any of you guys gone the route and installed a Dana 60
High pinion into your highboys. I recently installed one in my 76 F250 Highboy and have found that the front diff yoke hits my Headmen headers. I currently have a 360 Fe motor and C6. If any of you guys are running an Fe powered high boy with a High pinion Front diff , what kind of headers do you guys use. Its almost winter and i have to get my 4 wheel up and running. Thanks For any help
David
David
HELP
Can someone tell me what axles came in a 76 High boy from the factory? PLEASE!
Either reply here of email me at brian.morgan@consolidated.com
Thanks
Thanks
Personally you might want to see if you can find a high pinion one. With a low pinion you may have to much of an angle to put a driveshaft in or may experience severe u jouint angles that can cause breakage or parts to wear out to fast especially on such a short wheel base vechicle. Also you will be changing to an eight lug spindle and you may have to carry two spares if you dont have a rearend with eight lugs. Also by cutting it down your going to need to shorten your tierods and axle shafts. So before you go ahead and cut it, check out what you will spend in new axles and tierods plus what its going to cost to have in shortened, you may be better off ordering one from a company such as Dana trac or currie enterprises.
David
David
Duckmang
07-23-2013 10:00 PM
428HIGHBOY
05-28-2007 08:37 PM
