Looking at getting a new turbo. Wondering about this "Garrett PowerMax Turbo 04-07 6.0L 772441-5001s" turbo. IS it worth getting if I just run the truck without any tunes? or should I just get the oem unit?
Since the PM is a bigger turbo you will get a slower spool up with the pm compaired to the stock turbo. The PM will lower exhasut temps, and add just a little power.
So if a guy doesn't plan on adding a tune.. Then you would suggest staying with a stock unit? I know the stock has a lag, but don't want have additional lag.
Just want you guys to know what you are dealing with. The PowerMax is fine, lags stock, a mild....mild change from a tuner would fix that. You don't have to burn the house down with tuning, just fix what you want. Tuning is a wonderful thing so don't be hesitant. Number 1 Rule, if you plan on adding more ponies and go for the big numbers.... head studs highly recommended. Tow or a file for the PowerMax to clean up the lag is no problem.
Just giving you my first hand experience with the PowerMax, not necessarily valid with other model years, see your local Garrett Dealer for details.... Someone else my chime in on thier installation and results.
