gear shift wiring
Old Sep 5, 2011 | 11:25 AM
stacy h's Avatar
stacy h
gear shift wiring
2004 f250 won't start unless I fool with gear shift wiring under fuse box panel.
Old Sep 5, 2011 | 12:30 PM
dchamberlain's Avatar
dchamberlain
This is a 6.0L diesel I assume? Won't start or won't crank at all? And I'm assuming it's an automatic transmission.
What it sounds like is that you have either a loose connector or a broken wire in the bundle that you are fooling with. The only thing you're probably going to be able to do is to carefully move one wire at a time without moving others until you find the one that will let it start. You're probably going to need a helper.
Before that, though, I'd push all the connectors in the area together to make sure they're fully seated. And I'd give a little tug on the each wire at the back of each connector to make sure none of them are loose.
Old Sep 13, 2011 | 08:37 AM
stacy h's Avatar
stacy h
wiring diagram for shift column
Do you kno where I can get a diagram for the shift column. Not good at wiring so I need a visual. Is there any way to tighten up the wires?
Old Sep 13, 2011 | 09:15 AM
Craig.Parks's Avatar
Craig.Parks
My '04 had the overdrive button wiring harness replaced in '06 due to wire chaffing. This is located in the column near the gear shift. This might also be causing your issue.
Old Sep 13, 2011 | 12:50 PM
stacy h's Avatar
stacy h
column shift wiring
It seems to be the two wires in the one connector. The gray/white & gray/red. Is there a way to tighten them?
Old Sep 13, 2011 | 12:52 PM
stacy h's Avatar
stacy h
@dchamberlain yes its a 6.0 diesel automatic
Old Sep 13, 2011 | 03:30 PM
Craig.Parks
I wish I could answer, but mine was fixed by the dealer back then.
Old Sep 13, 2011 | 04:06 PM
Rusty Axlerod's Avatar
Rusty Axlerod
It is possible to tighten them but difficult to describe. Determining wether the pins in the connector are loose in the receptical or the wires are loose where they connect to the pins is the first step. If the wires are loose the metal pin can usually be removed from the connector by sliding a jewelers screwdriver in the back of the connector, unlocking the pin and pulling it out of the back of the connector shell. You can re-crimp it or use a touch of solder to repair.
If the pins are not making contact where the go in the receptical, unlock the the wires as previously described from the receptical half of the connector and slightly bend the now exposed tab to create more friction when the two halves are put back together. This is all kind of delicate stuff. another fix would be to cut the wires just behind each side of the connector two at a time so as not to mix up which ones to connect together, and replace the whole thing with a couple of generic crimp-on single wire connectors from the auto parts store, or even use butt splices.
Old Sep 17, 2011 | 09:23 AM
stacy h's Avatar
stacy h
Thanks rusty I'll try this and see if this is my problem.
pinkstonjj1
Apr 2, 2015 07:51 AM
frhrwa
Jul 6, 2012 06:54 PM
gojuice1
May 20, 2007 12:20 AM
BlueOvalDrifter88
1978 - 1996 Big Bronco
Oct 3, 2005 04:53 PM
Rtpjunior
Feb 15, 2003 06:25 PM
