Cruise
Old Sep 4, 2011 | 08:24 PM
Scorpolis's Avatar
Scorpolis
Question Cruise
can anyone explain how the cruise control works and how i can fix it? im not sure what exactly is wrong but anything can help
Old Sep 4, 2011 | 10:16 PM
TexasGuy001's Avatar
TexasGuy001
Is it plugged in at the master cylinder? Has the recall been done?
Old Sep 4, 2011 | 11:04 PM
Scorpolis's Avatar
Scorpolis
not sure what the recall is... i just took it out and everything was plugged in
Old Sep 5, 2011 | 05:19 AM
TexasGuy001
There is a recall for the switch on the brake master cylinder. It is known to short and cause fires. They give you a fuseable link for that connection.
Old Sep 5, 2011 | 08:09 AM
Eddiec1564's Avatar
Eddiec1564
If the truck is a 1990 F250, it will not have that switch on the master cylinder. Best place to start looking is fuses and the brake switch. Also there is a vacuum dump valve on the brake pedal that can get out of alignment. The valve is in closed posisition when the pedal is up, open when brake pedal is pressed to dump the vacuum out of the servo. This is what went out on my 89 F250 and was easy to fix. Just have to wiggle under the brake pedal assy and adjust the location of the vacuum valve.
Old Sep 5, 2011 | 08:56 AM
nebechanezer's Avatar
nebechanezer
does your horn work? on my '95, horn and cruise both get power from the same circuit.
Darrenkoke
6.7L Power Stroke Diesel
Jan 15, 2020 04:40 PM
Puroman
General Diesel Discussion
Jul 27, 2017 04:02 PM
mrad
Jan 13, 2010 03:30 PM
4x4superduty00
Jul 30, 2008 09:06 AM
HORSEFACE
Mar 15, 2007 10:03 PM
