charging system
Old Apr 4, 2003 | 12:35 PM
tamwill's Avatar
tamwill
Question charging system
I have a 30 amp fusible link between my selonoid and alternator, and the fuses only last about two weeks or so. They are not blowing out, but are actually melting. Does anyone know what is causing this? -TIA-
Old Apr 4, 2003 | 04:25 PM
Franklin2's Avatar
Franklin2
charging system
Have you upgraded the alternator? And or have a heavy load added such as a large stereo, lighting, or something like that?
Old Apr 4, 2003 | 07:27 PM
Mike W's Avatar
Mike W
charging system
I would measure the current to find out what is going on. You should not be putting out a lot of current on a normal basis.
Old Apr 4, 2003 | 09:47 PM
Howdy's Avatar
Howdy
charging system
Your fusible links don't really, "blow out". They will get hot, melt the insulation, then break when they pass the current rating. All they basically are is a wire about 4 sizes smaller than they should be. So I think your link is doing what it's suppose to. I don't know what year rig you have, but my 85 bronco shows a 16 Ga. wire for a 50 amp alt. and a 14 Ga. for the 70 amp alt.
First thing I would probably do was make sure I've been getting the right link wire and feel some of the wiring around the solenoid. Sometimes you can trace a short or overloaded wire by feeling the heat.
If your fusible link is the right size, then something is drawing a bunch of current. I would guess it would be something on a keyed power source, since you didn't say you had any dead battery problems.
Is all your electrical stuff acting OK? Other than the link, that is
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
