stroking a 400 more?
Old Sep 18, 2011 | 01:09 AM
  #31
crsmiffy's Avatar
crsmiffy
Ouch!! That's big? I'd imagine the blocks would have a fair amount of coin chucked into them to handle the HP they're after. MMMMM 496!
Old Sep 24, 2011 | 11:49 PM
  #32
wyoming4x4's Avatar
wyoming4x4
tranny stuff and carbs!
I run the low gear kit and love it. 1st/2nd gear reduction and 3rd 1 to 1. You can feel the engine rev differently with the low friction parts. I have a manual shift, reverse valve body and B/M pro ratchet shifter in my truck. Been running similar application for about 8 yrs or so. Once I got rid of the TCI converters my problems went away. Hughes xtm 43 really works nice but if you want to stall up to like 2000 they will work nice also. Mine is a 4wd and lower stall appliction and run up and down highway. I run on 40" hawgs and got 9.5 mpg running around 80mph about a week ago 800cfm 1:1 holley thought that was good transporting some 4wheelers on trailor for hunting. Truck really runs easy with carb set up cruising around 2900 to 3100 rpm. 472 bbf, air gap intake, 450 hrspwr. Looking at doing a quickfuel 850cfm vacume secondary with annulars. gonna have to get built by quickfuel to work in my application. Kinda pricey$$. calculating carbs. cubic inch x rpm x efficiency, divide by 3456 or 2820. If high end carb go 2820. 3456 is the standard for many yrs. On efficiency stock head is around .7 for calculations. 408 x 4000rpm x .7= 1142400, divide (2820) 405 cfm. If heads ported nice and hyd roller around .9 to .93 on calculation ball park on carb calculations. I tend to run a little bigger carb with annulars for 4wd and works nice. I do cubic inch x 2 = ? 408 x 2= 816 cfm and annulars seems to work decent for me but their is some tuning in metering plates and jetting which isn't difficult for me but can be for some others. I'm rambling and will catch you guys later.
Old Sep 29, 2011 | 09:07 AM
  #33
i-w's Avatar
i-w
doesnt tim meyer sell a stroker kit?
\http://www.tmeyerinc.com/
Old Sep 29, 2011 | 05:20 PM
  #34
crsmiffy's Avatar
crsmiffy
yup, discussed earlier in the thread.
Old Oct 2, 2011 | 11:56 PM
  #35
wyoming4x4's Avatar
wyoming4x4
barnett motorsports
nice site barnett cool stuff. nice knowing they are out their.
79fordrat
Jun 28, 2012 07:54 PM
wyoming4x4
106
Jun 11, 2012 10:27 PM
71dusterdan
Dec 28, 2006 01:55 AM
black angel
22
Jul 22, 2002 04:19 PM
solidaxle
Mar 11, 2001 02:48 PM
