Underhood few missing hoses
Old Sep 3, 2011 | 08:28 PM
grushko's Avatar
grushko
Hi. I recently bought a 1994 Ford E250 extended van with v8 5.8 liters engine and now i'm working on it. Today i decide to clean everything under the hood and i found few missing hoses - one was cut and another one didn't even has a hose itself.
Where are they supposed to go? (there is no air filter on the pictures because i removed it to clean up everything).
Thank you very much in advance!
Old Sep 3, 2011 | 10:18 PM
85e150's Avatar
85e150
Looks like the heater hoses to me. Should connect to the water pump or very near by for the return. See if there is a "loop" hose of that size on the water pump.
This usually means the heater core leaks, BTW
Old Sep 4, 2011 | 12:40 AM
Beanscoot's Avatar
Beanscoot
But the good news is that engine should be roller cam equipped.
Old Sep 4, 2011 | 03:41 PM
grushko's Avatar
grushko
Is any suggestions what should i do?
Old Sep 4, 2011 | 06:13 PM
85e150's Avatar
85e150
Did you find a loop from the water pump with the same size hoses?
You can hook up those hoses to a garden hose and see if you have a leak.
vidaliaman
Dec 4, 2017 06:29 PM
CourierYVR
Aerostar
23
Nov 17, 2013 11:46 PM
cutlass
Aug 9, 2012 02:55 PM
silan
Aerostar
13
Dec 4, 2006 04:40 AM
bobodean
Jun 19, 2003 09:26 AM
