Front Diff Not Engaging- Help
Old Sep 3, 2011 | 12:29 PM
FiberTEK's Avatar
FiberTEK
2006 F150, SuperCrew with 5.4
I just replaced the firewall actuator valve for the hubs, and went to try out the 4 wheel drive. The hubs engage and lock to the axle shaft, the transfer case engages and locks to the front driveline, but the front differential isn't doing anything. Is there an actuator for the front or did something break inside?
Old Sep 4, 2011 | 03:19 PM
FiberTEK's Avatar
FiberTEK
I'm hoping someone will chime in on this.
Old Sep 4, 2011 | 04:01 PM
shorebird's Avatar
shorebird
Read this; View topic - Front axle not engaging, HELP, HELP! A- Techs.!!! - Ford F150 Forum
Old Sep 4, 2011 | 10:09 PM
FiberTEK's Avatar
FiberTEK
Thank you for the link. I know my old 99 had the lever, but I didn't not see one on my 06. I guess I didn't look hard enough.
Old Sep 5, 2011 | 10:24 AM
FiberTEK's Avatar
FiberTEK
No wonder I couldn't find it...THERE ISN'T ONE!
The actuator system was used up until 2004, this is an 06.
Anyone else want to take a stab?
Old Sep 7, 2011 | 08:16 AM
FiberTEK's Avatar
FiberTEK
Does anybody have an exploded view of an 04-08 front differential?
Old Sep 9, 2011 | 08:13 PM
Jake_f16's Avatar
Jake_f16
Make sure the vaccume line on the front of the transfer case is not torn cracked or leaking. Make sure you follow it all the way on top of the transmission.
Old Sep 27, 2011 | 11:37 PM
EMB135Driver's Avatar
EMB135Driver
I had this problem occur last April during a Heavy Wet 18 inch snow storm (April 1st as luck would have it). Apparently, the original Vacuum Solenoid on the firewall was located right under the end of the weatherstripping for the hood, and the water would carry minute amounts of dust into the vacuum solenoid/vacuum lines. The redesigned solenoid has a cover on it that precludes water from getting into the system.
When I opened mine up it was filled with dirt, as were the vacuum lines down to the hubs. I took it to the dealership and they checked it out to find that hubs were filled with dirt and corroded pretty badly....My Truck is a 2004 with only 35000 miles on it..spends a lot of time parked and that must have helped as the corrosion was pretty extensive....they tried cleaning but the damage was done, so I had to pay to have them replaced.....it was close to $1300 for everying (some brake work in there too). Good luck.
Old Sep 30, 2011 | 06:38 AM
BARRY HAMPTON's Avatar
BARRY HAMPTON
Trailering
what kind of 4 wd shift do you have? manuel on the floor or a **** on the dash?
Old Sep 30, 2011 | 07:09 AM
FiberTEK's Avatar
FiberTEK
****. I found the diff is working. The problem is all in the hubs.
Old Oct 7, 2011 | 06:13 AM
60DRB's Avatar
60DRB
FT, Did you get this fixed/identify the exact problem? Have you seen this thread before? Good for trouble shooting 4x4 vacuum issues, which are the most common problem with the 4x4 system.
https://www.ford-trucks.com/forums/836438-everything-you-wanted-to-know-about-the-iwe-system-and-then-some.html
If the IWEs are at fault...
http://www.f150online.com/forums/2004-2008-f-150/360269-iwes-removal-replacing.html
the beast 1
Mar 2, 2019 07:05 PM
Smokey_7.3
Offroad & 4x4
Feb 18, 2014 12:17 PM
ford390gashog
2004 - 2008 F150
Feb 23, 2007 06:33 AM
1 TON
Offroad & 4x4
Jan 21, 2002 01:14 AM
ringkong
Offroad & 4x4
16
Mar 6, 2001 04:11 AM
