help died at stoplight!!
Old Sep 3, 2011 | 07:14 PM
brownie83's Avatar
brownie83
if i remember correctly...its down toward the bottom and at about the 2 o'clock position when looking down...i think. look for a yellow plug..it think thats the right color...anyone know the color?
Old Sep 3, 2011 | 07:18 PM
nookiemonster55's Avatar
nookiemonster55
see it in my chiltons manual... right next to the ipr solenoid correct?
Old Sep 3, 2011 | 07:20 PM
brownie83's Avatar
brownie83
to the left of it i think...right?
Old Sep 3, 2011 | 07:23 PM
nookiemonster55
yea looking down its dead center bottom of fuel filter bowl on the RIGHT is the ipr solenoid grabbing my camera now....if this is said plug and still blowing the fuse i am curious what to lead to now......
Old Sep 3, 2011 | 07:33 PM
nookiemonster55
this is what i unplugged ...[IMG]file:///E:/DCIM/Camera/2011-09-03%2019.25.29.jpg[/IMG]Name:  2011-09-03 19.25.29.jpg
Old Sep 3, 2011 | 07:34 PM
ToMang07's Avatar
ToMang07
Old Sep 3, 2011 | 07:43 PM
nookiemonster55
thats it... now what... anyone got suggestion?
Old Sep 3, 2011 | 07:47 PM
brownie83's Avatar
brownie83
still blows the fuse? my knowledge is very limited..sorry...maybe the chaffed steering column wire?
Old Sep 3, 2011 | 07:51 PM
ToMang07's Avatar
ToMang07
Is that After unplugging it, and plugging the fuse in with the power off and no keys in the ignition?
I would had guesses one or the other....column wires or heater.
Other than that....check your wiring well.... which fuse (and whats it power) is it that's blowing again, according to your manual?
Old Sep 3, 2011 | 07:58 PM
nookiemonster55
hummm think i put fuse back in after i hooked batteries back up... like i said it cranked had gauges ran for 2 seconds and kaputted again...like i said ... gotta feeling this is gonna be expensive fuse 116
Old Sep 3, 2011 | 09:01 PM
sand_fiend's Avatar
sand_fiend
I had the same thing happen about two months ago.. I chased everything down. Every plug, fuse and relay on the fender-well.
just as i was gonna give up, I totally unplugged the main wire harness to the motor on the right driver side valve cover and plugged it back in..
That worked and it stopped blowing fuse's. The first time i just wiggled that plug.. Totally unplug it and replug and try.. I dont know why it did it but who knows..
If i remember right also.. That same fuse powers the fuel pump. crawl under and unplug the fuel pump wire and see if it still blows the fuse when you turn the key on... Just a thought...
Old Sep 4, 2011 | 01:13 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Fuse 116 has a few things on it, fuel bowl heater is most common to go but a chafed wire going to ground anywhere on that circuit will blow the fuse again. As said above the main harness near the 42 pin connector can rub on the valve cover and short, good place to start looking. Keep the fuel bowl heater unplugged to rule that out. Good luck!
Old Sep 4, 2011 | 11:11 AM
  #28
ToMang07's Avatar
ToMang07
Yeah, that's a good point....
OP, Check out the wiring harness on the driver's side valve cover, right under the air intake hose. (10mm bolt to remove the harness) It's a common place for the wires to rub through and chafe on the valve cover, causing a short.
Good Catch guys!
Old Sep 4, 2011 | 02:30 PM
  #29
nookiemonster55
will do guys will check today... keep fingers crossed!!!
Old Sep 4, 2011 | 03:38 PM
  #30
nookiemonster55
yep see where its rubbing the valve even rubbed some adhesive or some type of labeling off of the vc.... diving in now pictures to come!!! god i hope this is it....
