98 ranger misses
Old Sep 3, 2011 | 10:05 AM
socalarcade's Avatar
socalarcade
98 ranger misses
the check engine light is not on last time the light came on and it was a miss fire at # 4 plug but now the truck misses any ideas
Old Sep 3, 2011 | 10:19 AM
michigan66's Avatar
michigan66
It still may be worth going to an auto parts store that will check the truck's memory at no charge to see if there are any stored codes. If so, post the numbers here and we can give you some help.
By the way, what engine do you have? Also, what did you do when you found out that cylinder # 4 was misfiring?
Old Sep 3, 2011 | 12:59 PM
socalarcade
i have a 4.0 engine and the wire was changed on # 4
Old Sep 3, 2011 | 05:58 PM
michigan66's Avatar
michigan66
Do you have any idea which cylinder is misfiring? Something is missing in either the original information or in follow-up replies that will give use some clues as to what is going on with the ignition system.
Aerobane
Sep 16, 2012 11:09 PM
Derding
Jun 2, 2008 10:43 PM
rguy
Feb 28, 2006 06:09 AM
berle
Apr 7, 2003 10:01 AM
stonedevil
Jul 25, 2001 03:48 PM
