battery drain, 2003 f350 7.3
I have some questions about wiring on my 2003 f350, Aft of the battery on the passenger side is a solenoid, appears to be a starter assist relay. on the battery side of this relay, are 2 pair of gray wires, about 14-12ga, always hot. One pair constantly draws .68 amp from my battery, all the time, except occasionally it jumps to over 1 amp, and something whirrs for a second or two. With this disconnected, I have no power to the key switch. I'm considering adding another relay for this circuit, so it is only hot when I turn it on. Is this a common Ford trick???
yep, I left the glow plug link on there, because that relay is via the key and the pcm. I pulled the link for the alternator, and added another relay next to the start solenoid. I will feed that from the hot side of the solenoid with #4 tinned cable, and this relay will be acting as a battery switch to control that previously hot link to the alternator. I don't drive this truck often enough or far enough to allow this battery drainage. I was going to install a battery switch, but raising the hood to turn it on or off doesn't appeal to me, so I will control this relay from a dash switch. Thank you for the reply.
Hotairjunkie
Electrical Systems/Wiring
08-26-2020 02:01 PM
Nextdoorf150
03-28-2013 01:52 PM
