Setting the speedometer
Old Sep 2, 2011 | 10:57 PM
rmrichards949's Avatar
rmrichards949
Ok fact first. My 05 Ex XLT with a v10 has bigger tires (37") and the only way I found to adjust the speedo is either a Accuspeed or Speedrite (I think) due to the fact that the speed sensor runs to the ABS module. Programmers do not adjust the speed when it goes to the ABS, so the Accu or SR is required. This I have done and works great.
Problem. Just bought an 05 Ex LTD with a 6.0L. with bigger tires (37"), a friend says the diesels are different and a programmer will be able to change them. His knowledge stems from a 2002 F250 with 7.3L.
Question: Does the diesel 05 Ex speed sensor still run to the ABS and can't be changed by a programmer or are the diesels different from the gassers in this respect. I would like to get my speedo fixed and I don't want to purchase a Accuspeed if a programmer will do the trick.
Any ideas??
Thanks in advance,
Old Sep 2, 2011 | 11:58 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
The V10 uses the ABS sensor to read the speed.
My 7.3 diesel also uses the ABS sensor. To my knowledge the 6.0 also uses the ABS sensor for this.
However! My 7.3 diesel uses the same ABS sensor as the V10, and you CAN change the speedo with a proper tuner (high quality ones). So I dont see why you cant do that to a V10. However the 6.0 may be different.
Old Sep 3, 2011 | 10:20 AM
jdadamsjr's Avatar
jdadamsjr
not sure that's right....
while my sct tuner allows adjusting the revs/mile to help the tranny tuning program know when to shift, none of them, that I know of, change the speedo...
and Trey, what treatment did you give to the first responder in your sig ? OH, you "treated" the patient too !!!!!!!
Old Sep 3, 2011 | 01:53 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
There is a tuner that will do it. I think its called a scan gauge. Or something like that.. I cant remember. The best way it to get an AE.
I believe someone called 911 because the woman "couldnt be aroused"
Old Sep 3, 2011 | 02:23 PM
rmrichards949
I have a SCT tuner for the v10 and no dice, even tech support said it would not change it, and no plans were in the future to do it. A call to both Superchips and Hypertech confirmed they do not do it also.
Called the local ford dealership and they said they could not on the v10, then called Tommy Vaughn Ford a SVT dealership that does high performance mods and they said it was a 50/50 shot if they could.
Old Sep 3, 2011 | 02:26 PM
rmrichards949
Jd...that is correct I could change the revs/mile and the axle ratio (as I switched to 4.88s), but the speedo was still wrong. That is why I went with a Accuspeed.
Just wanting to make sure the diesel was the same or not.
Old Sep 3, 2011 | 02:28 PM
rmrichards949
[quote=TreySpooner65;10770314]There is a tuner that will do it. I think its called a scan gauge. Or something like that.. I cant remember. The best way it to get an AE.
I thought the scan gauge II was just a monitor. I did not think it actually tuned anything...am I wrong? Also what does AE stand for?
Last edited by rmrichards949; Sep 3, 2011 at 02:30 PM. Reason: Condensed all posts into one
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Hmm that is interesting. It is definitely possible with a 7.3.
Old Sep 3, 2011 | 02:30 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I dont think the ScanGauge will "tune" anything. But I think it will fix your speedo. AE stands for AutoEnginuity. And it WILL fix your speedo.
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
Old Sep 3, 2011 | 05:49 PM
jdadamsjr's Avatar
jdadamsjr
I have the scangauge II too (actually have TWO SGII's too !) does that make 4 ?
and it does not change speedo....
Old Sep 3, 2011 | 06:52 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Maybe its the 6.0 then..
Old Sep 3, 2011 | 08:11 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Just remembered.. Its the Snap On scanner that does it.. Not Scan Gauge. I knew there was another one other than the AE.
Rivieraman71
Apr 1, 2019 03:40 PM
traildogg
Apr 19, 2011 12:33 PM
F-250beast
Feb 28, 2011 08:08 AM
phat bastard
Mar 2, 2003 05:37 PM
chuckwpb
Aug 10, 2002 08:37 PM
