Sponsored by: Real Truck
ABS/Speedo problem '00V10
Old Mar 2, 2003 | 04:25 PM
phat bastard's Avatar
phat bastard
I was coming home on the interstate today and the ABS light came on. Then, as I slowed down to make a turn, I noticed that the speedometer went out. It seems to only happen below 45 mph. I remember a post a long time ago about a rear axle sensor.
Do any of you have some instight to this problem?
BTW-- It has not gone into "limp" mode.
It's a 2000 V10, 6" lift 38's
Thanks in advance........
Old Mar 2, 2003 | 05:37 PM
GAV10's Avatar
GAV10
Yep.....that what it sounds like. Really easy to change, part less than $15.00. If you are running 38's you don't even need a jack, just slide right under there.
Mark
