Sponsored by: Real Truck
abs & speedometer problem
Old Feb 27, 2011 | 09:49 PM
F-250beast's Avatar
F-250beast
i was driving home and my abs light came on then i noticed that my speedometer needle would drop and then got back up to the speed i was at. then would keep doing that wonder if anyone might now what is up with it. i have a 99 F-250 with V10
Old Feb 27, 2011 | 09:58 PM
Bigpipes 35's Avatar
Bigpipes 35
My first thought would be the vss but I am sure someone will be along shortly that might know more.
Old Feb 27, 2011 | 10:05 PM
cubantech's Avatar
cubantech
i would start with the vss sensor on the rear pumpkin.
it's a easy fix. Start there the sensor is sometimes called the abs speed sensor.
Old Feb 27, 2011 | 10:12 PM
F-250beast's Avatar
F-250beast
alright thanks i was kinda thinking it was probably that again i had replace it a few months ago. but ill give that a try again since its cheap fix
Old Feb 27, 2011 | 10:33 PM
cubantech's Avatar
cubantech
also check your gem.
I had a water leak that caused my gem to go bad and it would cause the same problem. the GEM is located right behind the fuse panel inside the truck.
Old Feb 28, 2011 | 08:08 AM
F-250beast's Avatar
F-250beast
so went to start it up and drove it a few miles this morning and the abs light didnt come on at all and speedometer works fine. hopefully was just a little glitch or something but thinking of still replacing the vss. but did find out my i have a coolent leak some were antifreeze was down. think i had a small leak for while cause it was down before.
Jude Hosey
Feb 2, 2017 08:12 AM
luismadrigal
27
Feb 7, 2016 09:10 PM
Taylortd
Oct 13, 2015 09:35 PM
Cabledude
Oct 5, 2015 11:34 PM
KaiserKlauss
Jun 16, 2015 06:02 PM
