what size spacers?
Old Sep 2, 2011 | 05:59 PM
05blueEx's Avatar
05blueEx
what size spacers?
I put f350 18 inch rims on my ex now it rubs slightly when full turned and when body rolls in the rears slightly. So i think i need spacers so what size would i need to get or should i just deal with it?
Old Sep 2, 2011 | 07:15 PM
wpnaes's Avatar
wpnaes
Spacers are exp$en$ive unless you can find some used ones. I live with a little tire rub with my 315's at full lock in front. I say spend your $ on other stuff for the Ex. A Helliwig rear anti-sway bar would take care of your body roll. Not sure which Ex / Engine you have?
Old Sep 2, 2011 | 07:20 PM
05blueEx's Avatar
05blueEx
Its a 05 with the v10 4x4 Yea only rubs at full lock but for some reason the left rear rubs the inner well when body rolls making right turn or heavy bumps no issue with the right side though.
Old Sep 2, 2011 | 07:28 PM
wpnaes's Avatar
wpnaes
If you can see where it rubs in the rear, take a picture and we'll figure out a cheap fix for ya.
Old Sep 4, 2011 | 09:23 PM
RACERX7775's Avatar
RACERX7775
many have done this mod. 2" spacers are required as the backspacing changed on 05+ superduties.
Old Sep 5, 2011 | 06:57 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I personally would do the spacers. The new rims narrowed your track width by 4" overall from stock. Do the 2" spacers to get that 4" back
The wider track width will make your X more stable, and kill the rubbing issue
Oval_obsessed
Mar 29, 2012 07:08 AM
markpruitt63
15
Mar 31, 2006 11:06 PM
porschebreath
2004 - 2008 F150
Sep 29, 2005 09:25 AM
bsprowl
Aug 15, 2001 12:15 AM
beefcake_431
Aug 2, 2001 01:43 PM
