Does anyone have a what hits and what fits tire guide for a 97 F350 4x4? I have 285/75/16 on now and am thinking about filling up the fenderwells a bit more.
You can run 315/75r16 tires (same as 35x12.5). I'd run them on a 10" wide rim with 4" backspacing or less so they won't rub at full lock. The bumper might need to get trimmed though.
This doesn't fit. 3 inch body lift, 33X12.5X15 on stock rims. Rubs at full lock bad!
I'm running 33x12.5x15's on stock Ford rims on my '92 2wd with a 3" body lift and 1.5" level. They fit just fine... rub on full lock but there's an easy fix to that. Just don't turn so sharp.
i like that minnesota, ive found thats a good solution too. lol
The down side is that you end up with a turning radius somewhere in the neighborhood of a small state.
