Video: What causes this? Turbo surge?
Old Sep 2, 2011 | 04:19 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Any one know what causes this? If I had to name it, it sounds like a flutter to me.
Turbo Flutter - F250 7.3 Powerstroke - YouTube
Old Sep 2, 2011 | 04:25 PM
VegasFordSD's Avatar
VegasFordSD
Sounds like turbo surge to me... gonna need a wicked wheel or a new compressor housing to cure it.
timmyboy76's Avatar
timmyboy76
was goona say, i see/hear nothing but the trans shifting, UNTIL the last 5 seconds, then you can hear the "flutter".
Old Sep 2, 2011 | 04:26 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I have added annotations on the video to show the flutters.
Old Sep 2, 2011 | 04:39 PM
ToMang07's Avatar
ToMang07
WW Time.
Old Sep 2, 2011 | 04:44 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
It ok to have that or it need to be fixed?
Mine does at 15 or higher psi it needle on boost would start shake between 1-2 psi back/forth.
Old Sep 2, 2011 | 04:46 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I would also like to know if this is "bad"
Mine ONLY does it when I am WOT at around 20-25psi. 1-20psi it is smooth sailing on the gauge.
Old Sep 2, 2011 | 04:51 PM
ToMang07's Avatar
ToMang07
If I remember correctly it damages the shaft, causing pre-mature bearing/turbo failure.
Someone correct me if I'm wrong... but thats what I remember reading.
I know you can get the WW CHEAP from XDP... and they have a sale going on right now.
VegasFordSD
It's not good... can result in a turbo failure
Old Sep 2, 2011 | 04:59 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Ok. A quick search has turned up 3 compressor wheels.
Bog Warner: Riffraff Diesel: Borg Warner Anti-Surge Compressor Wheel
e99 Wheel (no link found)
XDP: Xtreme Diesel's X-Wheel Compressor Wheel
Any differences or any one better than the other? I'm leaning to XDP
Old Sep 2, 2011 | 05:05 PM
ToMang07's Avatar
ToMang07
Same thing, different names.
Old Sep 2, 2011 | 05:08 PM
ToMang07's Avatar
ToMang07
Replacement O-rings for Ford Diesel Engines
Guzzle's comes with a turbo re-mount kit too.
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Ok cool. XDP it is then. Just not right now. School has sucked me dry of money. Plus registration is due next month and I got a ticket
But that one is my fault.
Old Sep 2, 2011 | 05:09 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Do you have to take the turbo off to do it?
Old Sep 2, 2011 | 05:11 PM
Milwaukee1979F150
Ok what if it already had turbo suring that mean we can't swap new WW and expect it be ok?
I know mine had almost none play in shaft so that still good? Going check again in later.
