Coolant Cap Question
Old Sep 2, 2011 | 06:55 AM
Chief-e9's Avatar
Chief-e9
Do 6.0 coolant cap's fail very often and how do you test one to see if it has failed? Found white chalk substance on driver's side of engine after towing and want to check simple (cheap repair) stuff first. Ha! Thanks in advance, Roy
Old Sep 2, 2011 | 07:48 AM
Rusty Axlerod's Avatar
Rusty Axlerod
I guess you could pressurize your degas bottle with an air compressor and a couple of fittings. Much easier to just replace it tho.
Old Sep 2, 2011 | 08:26 AM
69cj's Avatar
69cj
Ford came out with a re-designed cap a couple of years ago. They're only about 8 bucks. Cheaper than screwing with the old one.
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
You didn't say which year truck yours is.
Here is a picture of old style cap, to new style. (old on left)
Old Sep 2, 2011 | 08:30 AM
Rusty Axlerod
+ you can drill your old cap and put a nipple in it and attatch a gauge to check cooling system pressure if the new cap don't fix it.
Old Sep 2, 2011 | 11:45 AM
bismic's Avatar
bismic
Ford recommends installing a new cap if the old one ever relieves (PSV's are prone to weakening when they relieve a hot fluid).
Old Sep 2, 2011 | 03:34 PM
da-bees's Avatar
da-bees
Two very good too knows within a single thread.
Old Sep 3, 2011 | 03:26 AM
npccpartsman's Avatar
npccpartsman
Speaking of new caps.......I PM'd back and forth with a guy on the .ORG that had recently gotten a new degas bottle from Ford that came with a 20 psi cap although he didn't know what the part number was. I wish someone else could confirm this. Heard anything about it?
Old Sep 3, 2011 | 05:47 AM
bismic's Avatar
bismic
Originally Posted by npccpartsman
Speaking of new caps.......I PM'd back and forth with a guy on the ORG that had recently gotten a new degas bottle from Ford that came with a 20 psi cap although he didn't know what the part number was. I wish someone else could confirm this. Heard anything about it?
Have not heard anything about a 20 psi cap. I will ask around though!
Old Sep 3, 2011 | 06:18 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Anybody have the part number for the new cap
Old Sep 4, 2011 | 12:47 PM
Chief-e9's Avatar
Chief-e9
My truck is a 2007 F-350 dually. Anyone know what is the difference in old versus new cap?
Just bought a 60 month/60,000 mile bumper-to-bumper warranty from dealership where I bought truck. Hopefully, if it's more than a cap will be covered. ha! Thanks for replies.
Old Sep 5, 2011 | 05:20 AM
npccpartsman
Have not heard anyhing about a 20 psi cap. I will ask around though!
I really gotta start drinking my coffee before typing in the morning. It wasn't here it was on the .ORG, so fix your post and my quote--LOL. I'll see if I can get the guy to read the part # from the cap label and get it run also.
Old Sep 5, 2011 | 05:29 AM
bismic's Avatar
bismic
Definitely interetsted in more info on it!
Coffee time for me too!
Old Sep 6, 2011 | 04:03 PM
npccpartsman
Ford and motorcraft part numbers for 20 psi degas bottle cap:
9S4Z-8100-B RS-529
Why would you only want to run the higher pressure cap in colder temps? I assume it's because it raises the boiling point significantly?
Old Sep 6, 2011 | 04:13 PM
bismic's Avatar
bismic
Thanks Tim - reps to you (when I can)! Seems like you would want the higher pressure cap in the hot weather instead of cold. I wonder if the cap would help reduce cavitation issues - directionally it should anyway.
