Problems refueling?????
Old Sep 1, 2011 | 10:11 PM
ihf-350's Avatar
ihf-350
Ok this is gonna sound extremely stupid but, when I have went to the pump the last two times it takes forever and i can't pull it and lock it. I pull it then it clicks like it is full I have tried both tanks the time before it started doing this i filled up the rear no problem then filled up the front the next time and it was doing this. Then tonight i was putting it in the rear and was doing the same thing the front did. Could there be a problem with my fill hoses, I looked they aren't kinked, or what IDK???????????????????????
Old Sep 1, 2011 | 10:29 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Vent hose!
Ford vent hoses are to small to start with, and any small kink or anything will give you those silly problems. I have the same problems once in a while with my motorhome.
Old Sep 1, 2011 | 10:54 PM
ihf-350's Avatar
ihf-350
So is there a way to fix it or just deal with it?
Old Sep 1, 2011 | 11:03 PM
dyoungen's Avatar
dyoungen
I'm having the same problem you are. I"m replacing my fuel hoses from the filler cap to the fuel tank.
Old Sep 1, 2011 | 11:04 PM
84-6.9L's Avatar
84-6.9L
I had good luck blowing air back though the vent holes and cleaning them out. IIRC some guys pull the neck apart and pull the vent hose out and run it that way.
If you have issues until you can fix it find a pump that tilts the truck to the right of run the rear tire on a 2x4 when fueling
Old Sep 1, 2011 | 11:08 PM
91dirtydiesel's Avatar
91dirtydiesel
I have same problem, just have to hold it the whole time at the perfect angle...annoying
Old Sep 1, 2011 | 11:32 PM
7DF250's Avatar
7DF250
Had this a few years ago, when I would pull the cap I got a huge rush of air, more than normal, vent was bad and the vacume was collapsing the hose a bit giving it that flat sopt for the fuel to slow up and trigger the pump to stop.
old blue beast
Jun 7, 2014 10:05 AM
TXBDBY
General Diesel Discussion
Apr 23, 2013 01:42 AM
lscolonel
Sep 22, 2006 05:53 PM
dgeesaman
Feb 20, 2006 08:01 AM
fordmudrunner2020
Jul 28, 2003 07:18 PM
