Leaving for vacation tomorrow, STARTING PROBLEMS!!!!!!
Old Sep 1, 2011 | 04:11 PM
Firefighter 1406's Avatar
Firefighter 1406
Have already posted this in the Superduty forum but was told to post it here also.
It has happened to me twice in the last week. Go to start the truck gauges pop up like normal and after about 2 seconds, gauges dim and the drop dead just like I took out the key. If I go to turn it over after that then it cranks maybe once and it dead. Have tried to jump it when the problems shows it self and it will take at least 5 min before it will start. You can tell if it is going to crank if the gauges hold. I have two brand new batteries, new cables, and new alternator all last winter. Drove the truck 3 days in between it happening last time, probably shut the truck off and on 25 times. I am at a total loss. Maybe and ignition switch, or starter solenoid or something? Seems like a connection issue somewhere. Any help would be great.
Old Sep 1, 2011 | 04:23 PM
ScaldedDog's Avatar
ScaldedDog
New, or not, I'd still have the batteries and alternator tested. Are the battery posts and connections clean? Clean 'em, anyway.
Mark
Old Sep 1, 2011 | 05:14 PM
Firefighter 1406
Cleaned the battery posts and cables yesterday.
Old Sep 1, 2011 | 05:40 PM
Tailgate77478's Avatar
Tailgate77478
Do you have an original "black" CPS? If you do, that is your likely culprit. While they were the best CPS design for efficient running of the engine, Ford changed them because they would go out on you at a moment's notice...and have all sorts of weird symptoms like this.
Look for "CPS" or "Cam Position Sensor" to get instructions...takes 5 minutes to check with a 10mm wrench (to remove).
Old Sep 1, 2011 | 05:45 PM
Firefighter 1406
I had the cps recall done, so I think they changed them with the gray one, correct...
Old Sep 1, 2011 | 06:14 PM
Kwikkordead's Avatar
Kwikkordead
Sounds like you have a poor connection somewhere that powers everything.
Try swapping the power supply relays around and see if that helps.
That's all I know to say.
Shake-N-Bake's Avatar
Shake-N-Bake
I don't have any good suggestions other than to check and see if your chip is loose. I hear it's recommended that you have your keys out of the ignition while messing with that thing.
Old Sep 1, 2011 | 06:26 PM
VegasFordSD's Avatar
VegasFordSD
leave them in the house...locked in a safe... under 24 hour surveillance while you are messing with that thing
Old Sep 1, 2011 | 07:30 PM
Firefighter 1406
Kwikkordead, are you talking about the power relays in the fuse box? And if so which ones are they?
Gchavez and vegasfordsd, I have a PCM burn by dp tuner, not a chip so that is not a problem.
Also forgot to mention that I did take the truck to auto zone and they hooked up the truck and said that the alternator was putting out 13.8 volts all the time.
Old Sep 1, 2011 | 08:34 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Check your grounds and clean them good !!!!
Old Sep 1, 2011 | 08:58 PM
Bonanza35's Avatar
Bonanza35
Dose the starter drag with full batteries? If nothing else is found, connections etc., check the started for a short.
Chet
Old Sep 2, 2011 | 02:41 AM
Nsaan's Avatar
Nsaan
One of the batteries is bad, I had less then year old batteries in my truck when it was doing the EXACT SAME THING to me, if i drove it everyday it was fine, but if it sat more then 2 days it would have to be jumped to start. Make sure to replace/warranty them both and you should be good to go, I know I was. I have had no problems since then.
Old Sep 2, 2011 | 10:29 AM
Firefighter 1406
Alright, stopped and had the batteries checked. They 850 CCA batteries, drivers side was 835 and passenger side was 736. Passenger side was low but I don't think it would be low enough to cause a issue. What do you guys think? Problem is I know they are under warranty but it still tested good so I don't know if they are going to do anything with it right now.
Old Sep 2, 2011 | 11:25 AM
Brother Les's Avatar
Brother Les
It is still warmer enough to start with out it. unhook the GPR for now so you will not have power drain there. It sounds as if you have a short or a lack of ground somewhere. Did you test your starter?
Old Sep 2, 2011 | 12:50 PM
1996pwrstrk's Avatar
1996pwrstrk
I would check the grounds on the engine as all ready mentioned and the next time it does it check the voltage at the batteries .
terrylamar
40
Jan 21, 2014 08:46 AM
Firefighter 1406
Sep 2, 2011 10:27 AM
duke_snyder
13
Oct 13, 2009 10:36 AM
wfl_colorado
Sep 25, 2007 10:48 AM
liltoot
Aug 4, 2006 09:05 PM
