Sponsored by: Real Truck
front wheel hubs
Old Sep 1, 2011 | 10:05 AM
adisont's Avatar
adisont
front wheel hubs
does anyone know if the earlier wheel hubs (pre 05) will fit the later trucks (08 in this case). i have two that i had bought for a previous truck and now need to replace the ones on my current truck which is a 2008 f 250 4x4. The hubs i have are for 99-04 ford superduty 4x4.
Old Sep 1, 2011 | 10:12 AM
dchamberlain's Avatar
dchamberlain
No. Most of the front end, springs, hubs, bearings, hub locks and brakes changed in '05.
Old Sep 1, 2011 | 10:28 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The whole bearing assembly changed, so OEM hubs won't work right. And the last I checked, aftermarket hubs like Warns won't fit unless you get the stub shafts machined down about half an inch or buy shorter shafts. You could say we're getting the shaft because we're stuck with oem....
Old Sep 1, 2011 | 11:06 AM
maverick22's Avatar
maverick22
I'd never heard it before, but it was posted last night that Warn actually makes the newer OEM hubs. Did a little research and it's true. Can't comment for the auto's but my manual lockers seem to be pretty robust.
Warn Industries - Press Release: Hub Lock Technology
Old Sep 1, 2011 | 11:21 AM
texastech_diesel
Token Redneck
I'll admit I didn't know Warn made the manual ones... maybe I'll look into retrofitting those instead of the auto lockouts. When I did my research I wanted real Warn Premiums like we'd used on some older trucks, and there's no joy on that front. The biggest reason was I've rebuilt Warns and it's not hard.
OP was asking about an 08, and the last time I checked, the Warn 62672, listed for Dana 60 axles with 35 spline outer shafts, would not work on Super Duties after 2004, confirmed by Warn, Art, and the parts diagram. The problem is the older Warns are for a 30 spline stub shaft, and after 2005 when the bearings changed, it's a 35 spline shaftthat's slightly larger, and the Warn hub for that application can't handle the length of the stub shaft.
Either way his older hubs shouldn't work with the new bearings and stub shafts on the 08.
Old Sep 1, 2011 | 01:43 PM
maverick22's Avatar
maverick22
Correct, and I didn't mean to get off topic - just thought it was good information.
I guess I'm going to do it again though - the reason Warn can't make anything under their own name for the newer ones is that they're still under contract w/ Ford. That doesn't explain why Mile Marker or one of the others hasn't though.
Old Sep 1, 2011 | 01:57 PM
adisont's Avatar
adisont
thanks for the replys, i was actually interested if the wheel hub, the part with the bearings, would work with the newer truck. from the previous post it looks like they changed the spline count. so the older locking hubs would not work with the new stub shafts.
Old Sep 1, 2011 | 02:10 PM
suzuki0702's Avatar
suzuki0702
how much you want to sell me that hub bearing for since you cant use it?
Old Sep 1, 2011 | 02:15 PM
adisont's Avatar
adisont
i have a pair timken wheel hubs, new in the box, send me an offer to sheppard_10 at bellsouth dot net. i had bought them for an 05 but they had have the smaller center for the locking hub. i did a part number check an they are for 04 and earlier.
Old Sep 2, 2011 | 08:54 AM
burning coal's Avatar
burning coal
i cant get your email to work what will you take
Old Sep 2, 2011 | 11:18 AM
adisont's Avatar
adisont
i'm not sure what they are worth, i know what i paid for them. what is your email?
Old Sep 2, 2011 | 06:22 PM
burning coal
smitchell801@msn.com
Old Sep 3, 2011 | 01:34 AM
mountie's Avatar
mountie
So did Ford actually improve on the pre 05 hubs when they made the changes?
FoxClubNiner
Jun 23, 2016 08:10 AM
cdiddy
6.4L Power Stroke Diesel
Sep 1, 2014 11:28 AM
buckskin charley
Jun 13, 2009 12:22 PM
alchymist
Dec 22, 2007 03:33 PM
jasonlasvegas
Sep 29, 2004 08:19 PM
