P2006 code need help
Old Aug 31, 2011 | 08:47 PM
GwarForAll1021's Avatar
GwarForAll1021
So my new engine is throwing a p2006 code. Took it back to the shop that installed everything and basically said it's my problem. 500 dollar fix. Not happening.
So can anybody explain what's going on? How can I fix this cheap? The truck is a total dog. It's like driving my 1993 2.3 ranger :,(
Old Sep 1, 2011 | 02:10 PM
canstacker's Avatar
canstacker
I believe the part is around 110$ not sure how hard it is to replace though. You can search for more info. Good luck!
Old Sep 2, 2011 | 02:29 PM
shorebird's Avatar
shorebird
P2006-Intake Manifold Runner Control Stuck Closed Bank 1
It may be a plastic retainer clip that costs $6
Ford part #F5RZ9F955AB IMRC actuator rod retainers
www.partsguyed.com
Trademotion is Parts Guy ED. The source for anything Ford!
I found this about that code and fix;
Intake Manifold Runner Control (IMRC) - Car Forums and Automotive Chat
View topic - 2004 F-150 5.4l 4x4 Error Code-P2006 Intake Manifold Runner - Ford F150 Forum
Usually with this code it is a bad intake manifold runner control which is located on the back of the intake, and requires removal of the intake manifold to access. check the wiring from the PCM to the back of the intake when the intake is off looking for any chaffed wiring, also when you take the manifold off check and make sure that the rods for the intake manifold runners weren't contacting anything allowing them to bind. If that all looks good you will need to replace the runner control motor assembly. Keep in mind when installing it DO NOT move the actuator by hand any more than needed to get the rods on, this can damage it.
A thread from 5 years ago; https://www.ford-trucks.com/forums/5...-acuators.html
Another source gave me this; need to inspect the IMRC actuator at the intake to ensure the actuating rods are still attached, there is a plastic clip that breaks and will set this code, Ford part #F5RZ9F955AB IMRC actuator rod retainers
This is from my factory manual;
2008 ENGINE PERFORMANCE Electronic Engine Controls - F-150 & Mark LT
INTAKE MANIFOLD RUNNER CONTROL (IMRC) ACTUATOR - 4.2L
Fig. 26: Exploded View Of Intake Manifold Runner Control (IMRC) Actuator Components With Torque
Specification - 4.2L
Courtesy of FORD MOTOR CO.
Image here;
https://picasaweb.google.com/lh/phot...eat=directlink
Item Part Number Description
1 14489 Intake manifold runner control (IMRC) actuator electrical connector
2 0069 LH IMRC actuator rod
3 0068 RH IMRC actuator rod
4 N806549 IMRC actuator bolts (3 required)
5 9J559 IMRC actuator
6 9F955 IMRC actuator rod retainers
REMOVAL AND INSTALLATION
1. Remove the upper intake manifold. For additional information, refer to ENGINE - 4.2L article.
2. Disconnect the intake manifold runner control (IMRC) electrical connector.
3. Disconnect the IMRC actuator rods.
4. Remove the bolts and the IMRC actuator.
 To install, tighten to 10 Nm (89 lb-in).
5. Inspect the IMRL actuator rod retainers. Install new retainers if damaged.
6. To install, reverse the removal procedure.
This may be the part you need; The FORD part number for the bushing that is on the IMRC actuator rod is
F5RZ-9F955-AB . There is only one per pack.
An old TSB about rod retainers; Full Text Technical Service Bulletin
Old Sep 3, 2011 | 10:01 AM
canstacker's Avatar
canstacker
Sorry, I guess it was $110 for the dealership to fix that clip. $500 to replace the whole part, 2 new gaskets and some labor.
boxer.fan
1997 - 2003 F150
Aug 10, 2012 08:29 AM
JimTJr
1997 - 2003 F150
Sep 3, 2010 11:56 PM
NetCommuter
1997 - 2003 F150
Jul 9, 2008 09:11 PM
big60
1997 - 2003 F150
Nov 9, 2002 07:19 PM
davisr9
1997 - 2003 F150
Aug 28, 2002 08:29 AM
