oil filter O ring
Old Aug 31, 2011 | 07:40 PM
thinksnow's Avatar
thinksnow
oil filter O ring
I posted this over in the Expy section but know alot of the guys over here have alot of mechanical experience. Any help would be appreciated.
This is baffling me. I changed the wife's oil tonight (2007 EXPY EL). Everything went fine, nornal oil change. When cleaning up I noticed the rubber ring on the old oil filter was missing. Looking back the filter was tighter then usual getting it off. When I took the old filter off I wiped down the surface lilke I always do and didn't notice or feel anything unusual. I have searched high and low for the missing O ring to no avail. The truck is running fine and the oil pressure is fine. I got under the truck whille it was running to check the filter. It appeared to be seated fine and there was no sign of any leakage. The only thing I can think of is the old ring was stuck to the filter mount and the new ring seated against it. Is this possible and is it dangerous???
Old Aug 31, 2011 | 08:00 PM
2006powerstroke90's Avatar
2006powerstroke90
The o ring on the filter cap itself?
The new filter should have came with one.....and it should be replace every change...Do you always do it yourself?
Old Aug 31, 2011 | 08:25 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I assume you are talking gas motor. In the past when I did that, I removed the filter again and made sure I only had one gasket in there. Why take a chance that 2 are not better than one?
I think there would be a better chance of leakage between the 2 gaskets.
Old Aug 31, 2011 | 09:16 PM
dchamberlain's Avatar
dchamberlain
The seal on the old filter probably stayed on the filter mount, so now you have two seals on there. Take the filter back off and check.
This happened on a Toyota of my sons and it failed at the worst possible time, on I-80 outside Reno at 110 outside. Dumped all the engine oil on the freeway. So you want to get it right.
Old Aug 31, 2011 | 09:21 PM
amdriven2liv
^^^^ It's better to learn from someone who has been, than from someone who hasn't been.
Thanks for sharing David.
Old Aug 31, 2011 | 09:22 PM
amdriven2liv
And to "thinksnow". I'd rather not as of yet!
Just saying!
chadjones99
6.7L Power Stroke Diesel
19
Aug 21, 2015 02:47 PM
macguy
16
Oct 23, 2012 07:58 AM
thinksnow
Sep 2, 2011 09:54 AM
frenchy750
Dec 20, 2010 06:20 PM
PMarch
1983 - 2012 Ranger & B-Series
Sep 9, 2008 11:29 PM
