alternator wiring
Old Sep 3, 2011 | 07:26 AM
Franklin2's Avatar
Franklin2
This thread went the wrong way from the beginning. Let's start over. Your truck doesn't run, or it doesn't charge? Forget about the choke thing for now, it should not keep it from starting. Let us know what the problem is.
Old Sep 3, 2011 | 08:55 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Choke lead plugs into the alternator pigtail which should go to the "S" terminal on the alternator. Very interesting, my 1986 F350 with a 460 came with a 65amp internal regulator alternator. If you blow some of the internal diodes (there are 9) you get what you are describing.
Old Sep 4, 2011 | 12:07 PM
ritechous26's Avatar
ritechous26
Ive been wieghing my options with this old truck and decieded Im not going to fix it.THe old thing is has alot of cancer on it.The cab corners are gone along with the rocker panels,both floor boards have rust holes in it the bed is all rusted out and the tags are up in november.This old truck was my very first truck and I wanted to fix it up but it will cost way to much moey.I have found way better looking trucks on craigslist.I want thank everyone for trying to help me but in all reality the truck itself is beyond help.
Old Sep 12, 2011 | 07:32 AM
85lebaront2
FWIW, if anyone needs it I found a virgin (unmodified) 86 alternator harness for the 65 amp alternator when i was cleaning up some stuff yesterday.
Old Sep 12, 2011 | 07:51 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
There should be a small wire pigtail coming off the plastic choke housing.
Your stator wire will plug into this wire.
Old Sep 13, 2011 | 04:43 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
He said he has an aftermarket Holley, so He really needs 12V to the choke unless he swapped in the original Motorcraft 7+/-V choke element.
Old Sep 13, 2011 | 12:52 PM
81-F-150-Explorer
It will still work with the stator wire, just not as fast, and it will have to be set leaner on startup.
The choke should not be given 12 volt power with the engine not running.
Old Sep 13, 2011 | 01:12 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Choke should have NO power unless the alternator is turning.
This "feature" is so you can leave it to warm up, and if it stalls the choke won't open.
Without vacuum pulling a little air through the cap the bimetal coil spring will overheat and burn out.
Old Sep 13, 2011 | 02:08 PM
85lebaront2
I actually used the 7 volt Ford source on a few Holleys with good luck, the choke came off very nicely and not too fast.
Robert Lee Gill
Aug 12, 2015 05:14 PM
dstraw
Nov 28, 2014 12:38 PM
82 F150
Dec 8, 2010 09:15 AM
MTbuilder
Mar 7, 2010 10:42 PM
zeus77
Electrical Systems/Wiring
Aug 22, 2008 08:48 PM
