So I searched the forums, and the term Steering Wheel is a bit broad to search on and I can't find what I need to know. I just finished replacing everything in the steering from the wheels to the steering wheel. It all looks great, and the truck steers like a dream. The issue I have is that the steering wheel looks horrible. I am a near purist on my truck so replacing with a non stock wheel is not an option. DC wants $200 for a new wheel, and that is a bit steep for me. I found repair kits on Eastwood, and I assume there may be others.
So has anyone repaired their wheel, and did you like the results??
Well here is a bit cheaper wheel for you!
I repaired mine and it only lasted for about a year... I think the biggest problem is the heat! I just gave in and put a new wheel on!
Reproduced in black only by Carpenter (in China )...who had the puppy on display at the 2008 F100 Western Nats. "Squire" Don (camperspecial65) and I after inspecting it, came to a quick conclusion.
This wheel is quite a bit lighter in weight than the original, which means the inner steel tube is smaller in diameter. Conclusion: More plastic, less steel.
bum, I have never done it but have read good reviews over the years from guys that have rehabbed their wheels. A bondo like material is used to fill the cracks & gapps, then painted.
I don't know that "lighter weight" necessarily means less steel. I was told by DC or one of their vendor partners that the new wheels are made of a somewhat different material that *should* be more durable.
After examining my own wheel, pricing the kit and considering the time involved to repair it (with no assurance it would last with a newbie first time repair) I think the DC repro wheel is an excellent value.
Mine looks good at first glance, but then you see some pretty serious cracking.
So...after looking at all the options, I personally am gonna buy a Carpenter repro.
And, I'll probably end up buying my Styleside rear bumper brackets from them at the same time but sheesh....that's gonna be $350 order for just two items!!!
Growing old and restoring old cars and trucks aint for sissys
Check out my albums, I restored my steering wheel a year ago using West Marine's "West System" 101-TS Epoxy Repair Kit, and it still looks new...better than any wheel
I've ever seen. I have a bunch of photos showing how to do it etc. The Epoxy kit is about $50, and you'll only use one of the 4 packets that the kit
comes with. I've repaired epoxy surfboards with it for a while now, which are hard to fix, and this stuff works like a dream. I live in the warmer area of
CA, and no cracks or anything have shown up after a year of daily driving and sitting in the hot sun.
The key is the prep, and then using good paint and a healthy clearcoat. (I use PPG Pro Paint on all my jobs...)
I don't usually count my time on these trucks. If something is a real pain I might try to avoid it but learning new things is part of the fun for jugheads like myself!
What have you got to lose from trying to restore it? A little time and effort, epoxy, sanding and paint. A relatively simple task.
If it looks bad now, it won't look any worse in trying to repair it. If you're not satisfied with the first try, sand and paint again. It won't break the bank to try. If it turns out good, you've just added another item to your truck that you can be proud of, not to mention the money you'll save.
What have you got to loose from trying to restore it? A little time and effort, epoxy, sanding and paint. A relatively simple task.
I've rebuilt/restored a few steering wheels on antique tractors with epoxy. I recently sold a tractor that I had restored in 1953 and the steering wheel still looked very good.
