Engine doesn't want to start!
Old Aug 30, 2011 | 10:30 AM
1990FordF250Diesel's Avatar
1990FordF250Diesel
Question Engine doesn't want to start!
Since I bought my 1990 Ford F-250 7.3 IDI it has always taken a lot of cranking to start, and I just thought it was glow plugs, so I put up with it until I had time to change them.
I changed them today, but it still takes about 15 seconds of cranking before it eventually splutters into life.
I thought maybe it was water in my fuel filter, but the "WATER IN FUEL" light does not illuminate at all...
Old Aug 30, 2011 | 10:38 AM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
What brand of glow plugs did you put in?
I will assume that you replaced all 8?
How many miles on the injectors, injection pump?
You could have an air intrusion.
Does the engine idle rough on the first cold start of the day? Does it smoke when started? If so what color?
Old Aug 30, 2011 | 10:46 AM
Country_boy_2007's Avatar
Country_boy_2007
in addition to what 94idi said, how about the batteries, test the batts, check for good clean connections and grounds on the cables and check the cables themselves for corrosion, and finally check the starter these engines need to turn over at a fast enough rpm otherwise there hard to start
Old Aug 30, 2011 | 10:58 AM
'94IDITurbo7.3
Excellent point. i did not think of that. i cleaned up the grounds on my truck and i could tell a difference in how fast is spun over when i hit the key and before i cleaned the grounds it did not spin over bad at all. make sure the bat cables are in good condition. make sure the bat posts are clean. the guy that i got the truck from did not clean the posts and he said that the truck would start just fine sometimes and then not even click when you turned the key other times. turns out all hey had to do was clean the posts and it has worked just fine ever since.
Old Aug 30, 2011 | 12:49 PM
1990FordF250Diesel
Ah, it could be the batteries then. Because she does turn over a bit slowly.
I'll replace them soon and see if they fix it
Old Aug 30, 2011 | 10:20 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Wouldn't believe what new batteries will do sometimes
Old Aug 31, 2011 | 01:00 AM
1990FordF250Diesel
Right, well I'm just off to bed (late night!), got a hard day of chillaxin' tomorrow!
But before I buy new batteries, I've had an idea!
I'm going to go out now, take both the batteries out of my F-250, and put them on charge in the garage overnight, and maybe when I go to start the motor up at about 8AM, she will fire up easier!
Ah, that is what I love about having a 1990 Ford F-250 Custom with no options - No electricals to get broken by taking the batteries out!
I don't even have to worry about a radio code, as even if the radio had a code (don't know), it wouldn't matter, it hasn't worked since I bought the truck, I've just kept it there to make it look like it does!
I am hopeful though, there are plenty times I've had weak batteries and a good overnight charge kicks them back into life again, oh and a top up of the water!
Old Aug 31, 2011 | 10:24 AM
Country_boy_2007
dont forget to test the chargeing system also. last year my starter itself was getting weak, it would take 10 to 15 seconds to get my truck started. then my old starter locked up, i replaced it, and its been starting on the 3rd crank ever since
Old Aug 31, 2011 | 11:10 AM
snaponprofile's Avatar
snaponprofile
Like everyone above stated, diesels need heat to start, if there is no heat, it will not start. It is the starters/batteries job to spin the engine over fast enough to generate enough heat to start. If it spins over too slow, it will not start simply because of the lack of heat.
Mine has been cold starting on the 2nd crank for a while and warm starting on the first one.
Old Aug 31, 2011 | 11:39 AM
IDIDieselJohn
What kind of radio does it have? The factory ones like these?
If the fuse is fine, if you wanna keep the "original look" like I want, I went to Langlois Sound Performance & Detailling, at 279 McArthur Ave. and bought this after market original style radio for 40$.
I bought that cause the original one in my F150 is an AM/FM only. No tape, and I love my tapes
And amen on the Custom no options
Old Aug 31, 2011 | 11:41 AM
1990FordF250Diesel
Good news! I put the batteries on charge from about 2am until 9am, then hooked them up again, and after one glow plug cycle I cranked it over, and it turned really fast!
And better still, it started within 5 seconds of cranking, it usually starts after about 10 seconds!
So charging my batteries overnight cut the starting time in half. Result!
Old Aug 31, 2011 | 11:47 AM
1990FordF250Diesel
Yep, that is the radio it has.
When I think about it, I've got a box of about 150-200 cassettes (mostly country music, some rock and stuff) in the garage, so if I do get my radio/cassette working, I could sort out the best ones and put 'em in the glove box
It may just be the fact that the cable isn't plugged in right, or has snapped or something.
I'm good with electricals, so I'll take it out later today and have a look.
You've inspired me to fix it now
kneisl99
22
Apr 25, 2025 10:36 PM
fisherman2626
Nov 29, 2010 06:55 PM
twiztidfig
23
Mar 21, 2010 06:35 PM
Ztunamann
Apr 13, 2005 04:03 PM
DanAZ350
Jan 30, 2005 02:44 PM
