Sponsored by: Auxito
Battery light comes on
Old Aug 29, 2011 | 09:12 PM
Buzz44's Avatar
Buzz44
I put a new serpantine belt on my 98 F150 4.6 ltr. I did this because the battery light was comming on under load. The ammeter gage however did not fluctuate at all. I figured the belt was worn out and slipping under load. It is still lighting momentarly under load. Bad alternator I wonder the ammeter never shows drain. Anybody ever have this problem? Im hesitant to just replace the alt as this is the big alt for trailer package probably lots of $$$$.
Old Aug 29, 2011 | 10:23 PM
Bluegrass 7's Avatar
Bluegrass 7
You can have the unit tested for performance but still need to either service it or replace it.
Here is how the lamp works.
It has battery applied through the ignition switch.
The other side goes to the regulator mounted on the alternator.
When there is no charge the regulator provides a ground to light the lamp to tell you this fact.
Once the alternator rpm comes up to provide output, the regulator removes ground from the lamp so it goes out.
This tells you the alternator is outputting.
If it is intermittant, the alternator is faulty.
Likely brushes are worn and/or the commutator might be rough so the brushes can't keep solid contact at higher rpm.
Good luck.
Old Aug 30, 2011 | 11:04 AM
Buzz44's Avatar
Buzz44
Good luck.
Thanks Bluegrass 7 I will check it out. That sounds right because as long as I stay at low rpm you would never know a problem exsists.
Old Sep 5, 2011 | 05:44 AM
Tangosoldier's Avatar
Tangosoldier
Just recently I was having the same issue with my vehicle. I pulled my alt and had it tested. They handed back to me and told me it was working great... Still, my battery light was on, my head lights didnt seem normal, nothing seemed up to par. So, I did a little research and found out that when your alt is going bad it messes with your battery (but we all already knew that), but that being said my alt read high on my gauge when under load trying to charge the batter, but normal when at idle. Turns out it was over working trying to output the amps the car needed while still reading fairly normal volts. I replaced the alt and it made a world of difference.
Old Sep 6, 2011 | 12:44 AM
Buzz44's Avatar
Buzz44
I bought a new regulator and brush assembly but I have not installed it yet. I will post pics as I do it and update if it works or not. Stay tuned.
ed77
Modular V8 (4.6L, 5.4L)
20
Sep 3, 2020 11:15 AM
Vijay
Sep 10, 2014 11:13 AM
muff
1997 - 2003 F150
May 18, 2009 10:56 PM
myke
1997 - 2003 F150
Mar 16, 2005 06:49 PM
bobward737
Mar 26, 2003 08:43 AM
