Boost numbers?
Old Aug 30, 2011 | 11:44 PM
  #31
timmyboy76's Avatar
timmyboy76
Originally Posted by CampSpringsJohn
I installed an Edge Insight and have never seen anything past 14lbs of boost. In fact, when accelerating, the boost hits 14lbs, then drops off. Changed MAP sensor and unplugged the waste gate. No difference. What I did, thanks to the advice from the guy I bought the Insight from, was change the monitor to read IPR percentage and the ICP sensor. What happens in my case is that while the boost goes up, ICP pressure drops off while the IPR percentage continues to go up. He said that based off those numbers, I am either loosing oil pressure from the injector O-rings, a bad HPOP, or the HPOP is running out of oil, or the IPR is messed up. He believes it's the injector O-rings. He will, when time allows, pressurize the heads HPO and see if they hold pressure or bleed off.
thinking the same thing. Just tonight, tried to twist it, topped out at 14psi, pulling a single trailer w/ski (800lbs total). But more on the lines, the hpop is weak, for me. Oil pressure is good, not sure about IPR / ICP..
Old Aug 31, 2011 | 05:57 AM
  #32
CampSpringsJohn's Avatar
CampSpringsJohn
With mine, the ICP pressure can hit 3100psi very briefly, then it falls off to around 1500. As it drops, so does the turbo boost.
Old Aug 31, 2011 | 06:44 AM
  #33
timmyboy76's Avatar
timmyboy76
i gotta invest into an AE, along with a HPOP gauge.
Old Aug 31, 2011 | 07:33 AM
  #34
CSIPSD's Avatar
CSIPSD
Skip the HPO gauge and get a Scan gauge...
Knowing the HPO is neat, but does not tell you the other part of the puzzle, Duty cycle. Without that number you dont have a complete picture.
Old Aug 31, 2011 | 07:38 AM
  #35
timmyboy76's Avatar
timmyboy76
Alright! which one... Scan gauge | eBay
Old Aug 31, 2011 | 08:21 AM
  #36
CampSpringsJohn
Try this. I got the CTS.
Riffraff Diesel: Edge Insight CS/CTS
Old Aug 31, 2011 | 10:20 AM
  #37
CSIPSD's Avatar
CSIPSD
Aeroforce Interceptor Scan Gauge
I prefer the scan gauge to the edge monitors myself...
Old Aug 31, 2011 | 10:36 AM
  #38
timmyboy76's Avatar
timmyboy76
DAMN!!!...no need for gauges, with that badboy.
Old Aug 31, 2011 | 12:51 PM
  #39
CSIPSD's Avatar
CSIPSD
It will look at anything the PCM will moniter, however you will need to add a probe for EGT, and boost will only read what the map see's. So if your using a boost fooler or running more then 27# it will not read.
I like it as a back up or a #4 gauge with the basic EGT, tranny and boost gauges.
derek0525
13
Jan 19, 2016 03:57 PM
corksil
24
Jul 23, 2015 07:36 PM
crazer42
May 8, 2010 12:42 PM
RickyBR
19
May 25, 2004 04:35 PM
