Modular V10 (6.8l)
Intermitant miss, more under load.
Old Aug 29, 2011 | 07:05 PM
Airslot's Avatar
Airslot
Any thoughts? Truck has 171k on it. I've had it since 140k. I figured I'd do plugs and boots. Started this evening with #1 or #6, drivers side front as it looked to be the easiest one. Pulled that coil and boot and thought, hmmm, that boot and spring look damn good? Pulled the plug and it looked good to and had a gap of about .054. Spot on.
Then I slowed down and thought for a minute. Put the old plug back in. Started the truck, blocked the wheels, put e brake on, and put truck in gear to better hear the miss. I killed each coil one by one and they definately made a difference, so its not a dead hole?
Should I just go ahead and replace the plugs/boots.
Will a scan gauge !! do a drop cylinder test, or tell which cylinder is misfiring?
Thanks in advance,
Old Aug 29, 2011 | 08:17 PM
3cv's Avatar
3cv
I had the same problem and just did new plugs/boots without trying to figure out which was the culprit, the miss went away and I called it a win. I now know for sure how old the plugs/boots are as a side effect. If you still had a miss after plugs/boots then figuring which COP makes sense given the cost of just replacing all the COP for the heck of it.
Old Sep 3, 2011 | 01:52 PM
Airslot's Avatar
Airslot
All fixed up! Scangauge II said miss on #4. I was going to swap coils with one to see if the miss moved. When I did,I noticed some corrosion on the boot / spring. I replaced the boot / spring and problem solved.
Just thought I'd complete the thread....
Thanks all,
Old Sep 7, 2011 | 12:53 PM
Eugene373's Avatar
Eugene373
It's really odd, I've just had to replace #4 & #7 ( #7 blew a plug though ).. And everyone I talk to, seems to have issue's with #4 primary going bad.
Has anyone else noticed this as well?
~Eugene
leftylucy64
2004 - 2008 F150
Jul 7, 2020 08:26 AM
fordcrzymike
1997 - 2003 F150
Feb 4, 2013 06:17 AM
SCRWDRVR
2004 - 2008 F150
Feb 23, 2012 06:26 PM
BAJI26
Jul 5, 2007 04:08 PM
WarlockLord
Apr 15, 2007 10:19 PM
