I have a 02, F-250, 4x4, 5.6, auto, EXT-cab pickup. I pulled a code the other day 1155? I think. anyway it was for the driver side speed control sensor at the wheel. I checked it and cleaned it, but before I replace it I would like to check and make sure its getting power. someone in the past has messed with the dash wires ect. on this truck causing other wireing problems.
Can anone tell me what color the wire from the sensor to the back on the fuse panel? ( I want to check back of fuse panel to make sure I have power going to it)
and when should this wire be hot? (I want to check at sensor to see if I getting power)
