Help Please!!
Old Aug 29, 2011 | 05:23 AM
cmdevildog16's Avatar
cmdevildog16
Help Please!!
So i was throwing codes from EGR Valve and figured id take it out and clean it to get me through till payday, i got it out and cleaned it up pretty nicely just using a bruch as all the soot was soft but not wet.....well needless to say i was putting it back in and one of the bolts head broke off while tightening it....Does anyone know a way to get the bolt piece out thats stuck?
Thanks for any help!
Old Aug 29, 2011 | 05:53 AM
npccpartsman's Avatar
npccpartsman
If there's any of it sticking up then you might take a small chisel and try tapping it backwards or grabbing it with some channel locks.
Old Aug 29, 2011 | 06:13 AM
cmdevildog16
yeah ill have to look at it agian but im pretty sure there is nothing sticking up....do they make a Back out kit for things like this.....I thought i had heard somthing about some kind of back out kit?
Old Aug 29, 2011 | 07:28 AM
npccpartsman
It's called an easy out and requires drilling the center of the bolt. Sometimes with bolts like this if there's any kind of edge where it broke off you can take something (screwdriver, chisel, etc) and get on the very outer edge of the bolt and tap it backwards. I know that those bolts are small and in a very difficult spot and this technique takes a little finesse/practice but it does work. Other than that you'll need a very small drill bit and and an easy out, which has reverse flutes to screw into the bolt while you're turning it counter clockwise.
Old Aug 29, 2011 | 09:12 AM
florida_1959's Avatar
florida_1959
There are also "left hand twist" drill bits. If the bolt is not really cranked and stuck, sometimes the left drill will start to back them out then you can grab it with the channel locks. If not then the easy out is the recommended method.
Old Aug 29, 2011 | 09:54 AM
jampen's Avatar
jampen
You can take a dremel tool with a small cut-off wheel, carve a groove in the end of the broken stud, then use a flat head screw driver to back it out.
Old Aug 29, 2011 | 10:09 AM
cmdevildog16
Thanks everyone for the info looks like i have somethings to try after work today!
Old Aug 29, 2011 | 05:27 PM
2006powerstroke90's Avatar
2006powerstroke90
Let us know how you make out....
I think an easy out is the best bet if there is nothing sticking out of the hole
airsoft1779
Mar 25, 2013 07:46 PM
northwindone
Feb 1, 2013 08:28 PM
westkane
Sep 17, 2012 09:42 PM
seawulff
34
Jan 8, 2006 02:07 AM
ssKable
Modular V8 (4.6L, 5.4L)
Aug 9, 2004 09:48 PM
