Brake light circuit problem
Old Aug 30, 2011 | 01:04 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...s-diagram.html Have a read through this thread.
Old Aug 30, 2011 | 01:55 PM
Flatbedbill's Avatar
Flatbedbill
Great help! Unpluged the PCM. Rear lights are out. Now going to first check the grounds in the connector. Thanks!!
Old Aug 30, 2011 | 07:14 PM
Flatbedbill
Ok the low voltage bleed to the 511 circut is definetly comming from the PCM. Cleaned and resecured every ground I could find. When it is plugged in the rear lights come on. Not sure of all the circuit numbers to trace and test. For example pin # 91 on the PCM connector digram says cir 359 "sensor signal return"? Anyone have a list of circut numbers.
Old Mar 2, 2021 | 04:04 PM
Ethan Miles's Avatar
Ethan Miles
What did it end up being i'm having the same problem right now i'm going to just put load resistors on the truck
Old Mar 4, 2021 | 04:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
10 year old thread. don't hold your breath waiting for an answer, he has not logged on is over 5 years.
WPlayer
64
Sep 16, 2016 09:16 AM
fordf348
Jul 29, 2014 07:08 PM
beckman
May 10, 2013 09:56 AM
jlarsen513
Dec 31, 2011 08:02 PM
capt2c
Nov 1, 2005 09:45 AM
