Trans temp to high?
Old Aug 27, 2011 | 08:23 PM
white04kr's Avatar
white04kr
Trans temp to high?
Today the outside temp is about 107. My buddy has a 99 7.3 4x4. He text me and said at a stop light trans temp climbs to 220. driving is about 200. That seems too high. Im thinking the cooler is clogged. Any suggestions? Thanks
Old Aug 27, 2011 | 08:26 PM
allis327's Avatar
allis327
It may be possible that the bypass is stuck open if it has one. That was the problem with mine.
Old Aug 27, 2011 | 08:29 PM
snakedoc's Avatar
snakedoc
where is his gauge reading from?
Old Aug 27, 2011 | 08:39 PM
white04kr's Avatar
white04kr
allis- where will the bypass be if it has one?
snake- after market gauge I think its in the pan.
Old Aug 27, 2011 | 08:43 PM
snakedoc's Avatar
snakedoc
then he may need to change the atf it may be burnt.
Old Aug 27, 2011 | 08:47 PM
white04kr's Avatar
white04kr
Yea tomorrow I will be replacing the cooler with a larger style. I will look at the fluid tomorrow. Thanks snake
Old Aug 27, 2011 | 09:03 PM
allis327's Avatar
allis327
It is located on the side of the tranny and connects the inlet and outlet of the cooler lines. If your cooler become clogged the bypass opens because of the pressure and still allows fluid to flow and lube the tranny. I unhooked the outlet line from the tranny before the cooler and had no flow that was how I knew it was bad. Also had help from Mark. Do a search on tranny flushing and you will learn where the lines go and other good info.
Old Aug 27, 2011 | 09:13 PM
schlepprock250's Avatar
schlepprock250
The stock trans.cooler is very small,way too small for these trucks.....the cooler on the left is a stock 7.3 cooler,the one on the right is a stock cooler from an'06 F250...a 6.0 cooler...
Old Aug 27, 2011 | 09:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
These transmissions run 60-100°F above ambient. They can run 220°F all day long with NO problems. Your fluid is NOT burned from running 220°F.
The main problem with the early trucks is that they didn't have a cooler in the radiator and the air to oil cooler wasn't big enough, either.
Old Aug 27, 2011 | 10:30 PM
snakedoc's Avatar
snakedoc
i thought if ti got to 220 on the pan it was burnt, what temp is bad?
i have a aerforec gauge that reads the temp from the pcm how hot can it there before it is bad?
Old Aug 27, 2011 | 11:17 PM
Franko72's Avatar
Franko72
Molon Labe
My BTS was at 200 in traffic today @110* ambient.
Thats with my Tru-cool cooler and an upgraded OTW radiator, (my 26 row 6.0 cooler is still laying on the kitchen table....)
Adding a larger cooler is a great Idea, but My original trans lasted 240k with just the little stock cooler, so 200* temps no longer bother me.
We have gotten spoiled with the quest to have low trans temps...
Old Aug 27, 2011 | 11:24 PM
schlepprock250
Ya know Frank,you might be right with the quest for lower temp thing,while towing our TT in hills and mountains this summer,96* outside temp my trans temp stayed around 160/165,but when we left the highway and got in stopped traffic(more stopping than going anyway),the trans temps went up to 180/190ish and I started tripping,and mine being a 99.5 I don't have the OTW cooler,but all in all I knew it was OK.....
Old Aug 27, 2011 | 11:35 PM
Franko72's Avatar
Franko72
Molon Labe
You know Phil, Brian and I had a talk about this very subject. I kinda stole/quoted that last line from him.
If he's not concerned, than neither am I.
Old Aug 28, 2011 | 04:44 AM
Mark Kovalsky
The fluid will start burning above 400°F. That's not a typo, I said above four hundred degrees Fahrenheit.
Ford specs say it can run all day long with NO problems up to 220°F. You can go up to 250°F for no more than 1/2 hour at a time. If you get above 250°F you should find a safe place to stop and idle or fast idle in park or neutral to cool the trans.
Old Aug 28, 2011 | 03:59 PM
h2guy's Avatar
h2guy
I thought you could'nt get a tranny temp out of the PCM on the 7.3?
